They could have said it was due to running the engine at the stated max continuous power (so “in limits”) of 2700 rpm, but ah, we didn’t tell you that it should have been 2400 rpm.
Oh, the same figure of 2400 rpm that was suggested yonks ago, as all other Tutor operators used that figure as max continuous…?
Now I think that all the props have to be checked.
Odd, it shows it was sent to all-ocsqns, all-ocsections.ccf and allocwings. Must be something wrong with the distribution lists… Will PM you a screenshot of the list.
Also I’ve just had a look and found a DASOR that I’m pretty sure is why they are grounded. And it sounds serious… This oil leak wasn’t someone finding a patch of oil on the ground, lets put it that way.
