Stumbled across this on using AI - thought it might be helpful
That’s certainly a new take on RISE.
What’s RISE?
However thinking about it above - all are briefing or instruction techniques for that more strategic level
I’ve not used AI in any parade night yet so I’m thinking of revisiting it having read all the above.
Certainly something maybe for a cadet SNcOs to understand
I’ve tested it out, and I’m going to get one of our CIs to do an interest lesson on it.
It’s quite good for low-level planning I think, but it can’t do nuance. Plus understandably a lot of the references are US-centric.
Good one to try out, for anyone who’s interested: ‘what is the role of a JNCO?’ (then check NCO applicants’ answers against what ChatGPT says!)
Some online plagiarism checkers now include a score for AI generated content.
Worth noting though that even many universities acknowledge those checkers aren’t reliable whatsoever and can’t be used as sole evidence of academic misconduct. For an example: Artificial intelligence – an update on the university’s approach – Campus News
Given there are now tens of thousands of generative AI models, it’s almost impossible to create any form of checker that will reliably identify the presence of any of them.
I did hear that one of the quick ways is that you insert the phrase “as envisaged by Batman” or some other unrelated person but put it in size 4, colour white font.
It gets picked up by the copy & paste & turns out something that initial reads right but turns into gobbletegook further on.
They are also being used by businesses to check if agencies are using Gen AI content. But they fail as the Gen AI systems are using the same content sources to train on.
Yeah, we’ve been getting mixed result running my daughter’s coursework through plagiarism checkers. Some of them mistake direct quotes for plagiarism, but are fine if you paraphrase exactly the same point without giving any credit to the originator. Others claim stuff that has merely been cleaned up by the likes of Grammarly as AI generated.
Some might very well argue grammarly is a form of artificial intelligence. Not necessarily the same type of generative AI, but AI nonetheless. This is the problem right, where do we collectively draw the line? Academia just isn’t ready for this.
At work people have tested set to create a risk assessment.
Although the specifics are sometimes different in terms of the templates people have required to complete, it definitely provides a shortcut in terms of aspects to consider on your risk assessment
We’ve been teaching the Cadets how to use it because they wanted to do a newsletter but the biggest challenges we had with the previous Sqn newsletter was that they didn’t have enough time to do it on parade evenings.
So we’ve been teaching them how they can write the key points of a story, using AI to get the structure / length and then adjusting it to their style of writing.
Technically it probably doesn’t save any time in the long road, but starting for a structure is much easier than starting from a blank page.
So I just did this:-
Air cadet central is a web forum for members of the RAF air cadets to discuss ideas and opportunities on ways to improve and deliver the experience to the air cadets.
Reading these threads
https://forum.aircadetcentral.net/t/has-the-atc-outgrown-the-raf/
https://forum.aircadetcentral.net/t/is-the-rafac-in-a-death-spiral/
https://forum.aircadetcentral.net/t/rafac-astra/
https://forum.aircadetcentral.net/t/the-beginning-of-the-end-the-capitulation-of-sw-region/
https://forum.aircadetcentral.net/t/dire-atc-cfav-decline-recruitment-and-retention/
https://forum.aircadetcentral.net/t/pillars/
Analyse the problems & common theme & create an action plan for the strategic, tactical & operational levels.
Will post the result in the most appropriate thread in a mo….
Just played with using Microsoft’s CoPilot to generate a poster about out Leading Cadet syllabus.
Not going to lie, I kinda dig it, just a shame it crops as a square
It seems they all still really struggle with doing good text in generated images.
ChatGPTs attempt. Still pretty dodgy and full of inaccurate info, but it’s not a million miles away from something usable as generative stuff continues to improve.
We’d need to use RAG, but that’s not free!
Used CoPilot today to create a BLUF
