Yeah, but future proofing would have been nice. The actual cables aren’t that much more, bulk of the cost was labour I’m sure.
Oh 100%. But if they can save £10 on a £2500 job they’ll do it :joy:
Starlink.
Id rather pour bleach into my eyes than support anything to do with elon.
Im paying £249
For ethernet port put into wall.
Cable being run externally into the eaves of the roof. Into a switch with 6 extra slots should i ever wish to expand the wired network
Then running the cable to a port just right by my desk
I thought that was a decent deal for something i could do myself but im too lazy too
Sounds pretty reasonable. You’ve clearly already committed, but have you tried power line adaptors? They often work a treat.
Yeah tried that too just getting intermittent results.
Kudos to the builders of this house :rofl:
They seem to be incredibly hit-and-miss depending on the wiring layout of the house. I use them at home, but going from one side of a room to the other, and it’s flawless. Just shows I am incredibly lazy, as it would be quite easy to run a cable and hide it. But means moving lots of things, so just went down the power line route :laughing:
If you can, get 2 cables run for redundancy. You only need to terminate the one or you could run them to a double socket at each end, shouldn’t cost too much more.
Think I’ve run 6 in my place. I think at least one of them is actually marked 6e though I purchased as 6.
Cable from router in living room to power line adaptor in hall, cable from hall to office PC, then the socket to the power line’s WiFi adaptor in the bedroom.
At this scale, not much of a cost issue and I don’t even know if they had cat 5 available where I got the cables. If my internet is ever faster then there’s no need to replace cables.
The Steam Sale.
It’s too good across too many games.
If you have even a passing interest in Wargaming, Command: Moden Ops is on offer
Had it before Musk went crazy, as it was a necessity given my location.
Wouldn’t recommend it over FTTP where it’s available; speeds weren’t amazing and latency was higher than normal.
It’s working okay for the AFU by all accounts.
SMS is borked again
SMS fires normally
SMS fails to fire
SMS on Safe, Check Scheduled Downtime
No Downtime Scheduled?
OBSTRUCTION
So OC can access SMS, but I was struggling, even after password changes, which have probably been flagged now for over attempting to log in.
I find having both logins a nightmare!
It doesn’t tell you which password is incorrect.
Not just me then. Heat related no doubt :rofl:
