No RAFAC personnel*** should wear RAF aircrew rank slides. They are not so qualified.
(*** unless of course, previously RAF aircrew brevet qualified.)
They don’t. They wear RAFAC Aircrew rank slides
They are not aircrew, regardless.
I agree. But the powers that be in the RAF approved the change.
I think I was answering a different question @MikeJenvey:
So I know people that are not “2FTS qualified” aircrew but do help on AGS. I don’t know what rank slides they wear but would assume regular RAFAC ones…
This is a point you have tried to argue before. Everyone agrees that VGS are not RAF Aircrew, but they are RAFAC Aircrew. Do you believe that a BA 747 captain is not ‘aircrew’ because they have not been through that RAF training syllabus, or that the pilot of a light aircraft is not ‘aircrew’ and therefore can’t go in to ‘aircrew only’ areas at airfields?
What someone has in their mind as being a valid use of the term ‘aircrew’ is not what is at debate here - it’s which CFAV wear aircrew rank slides.
Yeah if you have supernumerary staff that are not under the primary responsibility of 2FTS but are mainstream RAFAC they wear the non aircrew rank slides, but If they were transferred into 2FTS then they would wear the aircrew rank slides
So less about qualification and more just about primary posting. Makes sense, thanks.
Actually, I often suspect that RAF aircrew do indeed think that.
I know that.
So, staying on badging and rank slides. Could someone please tell me which sleeve badges are to be worn with No1 dress. Is it the white Royal Arms or the coloured ones or are they just for regional
WO
All WOs now wear these ones, be careful the non issue varient avaliable on all usual sources look like a childs tried to copy them
Thank you for that
Does anyone have a good place to buy some WO rank bages that don’t look like a 2 year old has drawn them. Seen some on ebay that look good but its £30 +pp for a pair ![]()
Wyedean come in and out of stock.
Currently they’re out, but keep checking or sign up to be notified when they restock.
