I was speaking with a friend who’s a service instructor about how the ranks work in the cadet organisations and I found myself wondering why it’s done the way it’s done…
You start at SNCO, regardless of whether you have as much experience as a senior cadet, you have officer ranks at the lower end that don’t get so much use (although I guess that’s changed a bit now, with everyone dropping back to flying officer), your SNCO ranks are gained in fairly short order, and aren’t linked to appointments like your officer ranks now seem to be, and there doesn’t seem to be any split between who can do what job, bar commanding a wing, which hasn’t yet been a SNCO or CI…
So I was just wondering, why don’t you start from scratch and link them all to roles.
You could all be SNCOs, bar sqn cdrs, sector cdrs, and wg cdrs, free to sail up and down all the ranks depending on your job.
Or, as you literally run a cadet NCO training factory, why don’t you all be plt off, key sqn roles are fg off, sqn cdr is flt lt, big wing staff jobs, sector commanders, and dep OC wing are sqn ldr, and OC wg is wg cdr?
Your sqn staff at plt off can still teach drill as some SNCOs may now do, they can still teach other subjects. Practice anything and you’ll be good at it…
HERESY! But I just feel like the way it is currently done is weird, and probably the result of incremental change to a wonky system.
Like Richard Dawkins and that nerve in the giraffe’s neck that should just go from A to B in a few centimetres near the heart, but incremental change through evolutionary time means it’s now feet long and goes right up its neck and back down again…
Anyway, something about simplifying your ranks and bringing more sense and status to them depending on the role you do…
Aaaaaand. Go! Tear me apart.
