Has anyone heard anything about the Shooting Hubs going - it’s being told as a Regional Instruction ready for L144 going.
It seems to have come out of the blue, there is still courses being run to get qualified on them and they aren’t that out of date. But they are quickly being “closed” the hubs but not the ranges
Its fine now it’s edited. A RC at one point was live updating on twitter as he went round a Wing delivering rifles once, so we’ve seen worse! Including photos from inside too!
As for your actual question of if this is happening everywhere, the answer is certainly no.
Cr@p design & spec - pay cheap, get rubbish. Should have accepted a higher price per unit to get quality off the shelf “youth” .22 target rifles (Anschutz, Walther, whatever) to guarantee longevity, servicing & add-ons.
I remember using a .22 conversion kit to fire the L85A1 on the indoor range at our old TA Centre, but I heard they were withdrawn when the L85 was upgraded to A2 standard (which would be ironic, because both were HK).
There is one and it has an official L number now but it’s expensive and I’ve not looked at whether it could actually be stored on units or is still section 5.
The conversion kits were okay if looked after but didn’t alter the rating of the weapon so couldn’t be stored on units anyway.
It should be a Section 1 forearm, as long as they haven’t just bodged it together.
Surely depends on how many you are buying? If we go out and buy 2000 plus the ACF, CCF and SCC that could make it more affordable. Imagine the savings in VA and other expenses if you only need 1 course for both weapons.
Typical “gallery” .22" rifles are semi-automatic & Section 1. Typical example - buy these & then cadets can start on simple mag drills, easy transition to L98A2.
