Lance Corporals in ATC
I feel like another JNCO rank would be a nice addition to the Corps so I’m wondering what the issues/reasons behind why we haven’t introduced it are
There are many cadets who may not be at the level of a Corporal which may benefit from Lance Corporal as a stepping stone
Acting Corporal, at least in my experience don’t get anywhere near the respect they should
Obviously I’m saying this as a cFS and I’m aware it’s not as simple as ‘here’s the new rank’
But I argue it’d keep consistency between the RAFAC and the CCF and with the recant introduction of the ‘Cadet’ and ‘Staff Cadet’ rank slides I feel like now is possibly the easiest time to do it
I agree. I also think the RMC should introduce CSgt and WO1/2, as well as the SCC introducing CPO and WO1/2. And we should have a second WO rank when the RAF do. It’d make everything so much easier
I’m just not sure there’s really a gap in the way an avg squadron organises themselves for the extra rank really, at least in my unit there’s not a lot of stuff that would sit below the level of supervision by a Cpl but above that of a cadet?
I’m not saying it’s a bad idea, not at all, but I think it would need a fairly hefty overall of the way squadron’s organise their flights/tasks/structure etc and I’m just not sure if it would bring sufficient benefit to a. properly utilise the rank and b. justify the overhaul.
I disagree. It can be used at the OC’s discretion. Just introduce it and allow OC’s to use at their wishes. Every sqn is different hence why I disagree with the idea of giving structures. I think a set number of JNCO and SNCO posts is necessary, but allow variation within that (ie, no set number of lances/corporals or sergeants/flights/CWOs) because otherwise a really good Sgt who is the unit SNCO I/C may never get CWO through no fault of their own. Instead, let them be CWO but only allow for example one other SNCO, and 6 JNCOs
V useful for us in CCF - and have been ever since the dim distant days of JCpls. But I have a unit of 55-60 cadets, so they are 3 x flights with a Cpl, and a couple of LCpls in each, then a Sgt and a FS above them.
Literally exactly how we operate. 1 FS as School Senior Cadet, 1 Sgt as 2 IC, 3 Cpls as Flight ICs then a few lances as flight 2 ICs
Although we may go to CWO and Sgt soon as the FS develops
It’ll differ from squadron to squadron, I do feel larger squadrons would benefit from this a lot more, but coming from someone from a somewhat small squadron, I know a few cadets of my own who’d benefit from this.
And yes I agree it’d massively effect how squadrons structure things like flights, duties and responsibilities and that isn’t necessarily a bad thing. I feel like to introduce this they could start with maybe a wing, see how they feel about it, get feedback, re-evaluate and depending on how it goes push it out to a region and then corp wide. I feel like you have to try something before saying it doesn’t work or isn’t necessary.
this is my take on it too
only recently the notes offered to the “Staff meeting” from the “NCO meeting” was they don’t feel like there is enough for them to do of a parade night (this was discussed it is in part because they are not working as a team and always the same faces doing the work) but if we were to add another structure into that I am not sure where they would fit…
We’re the opposite - the NCOs are always busy, both on parade nights and away from CCF. Then again, our Senior Cadet is our Trg Off too. I guess it just depends how your unit is set up
For me I feel like they’d fit as a probationary role, similar to ‘Probationary Sergeant’ and ‘Acting Pilot Officer’ without the expectation to go further
So a Lance Corporal can gain the opportunity to get promoted to Corporal but isn’t expected to take that opportunity
So for example:
Requiments for Lance Corporal:
First Class and Leadership
And cadets must hold the rank of Lance Corporal for atleast 3 Months, and complete Leading and attend a JNCO course to apply for Corporal
It’s a very bare bones example, but you get the idea, it gives those who are good candidates more responsibilities and develop with their rank, for me becoming an NCO gave me a well needed confidence boost.
I’d love to hear what the CCF do with Lance Corporal and see what they like and dislike about their current system
I don’t see the point of those for staff so certainly don’t see the point for Cadets.
It will just lead to rank suppression, you end up with Lance Corporals replacing Corporals, until you only have a couple of SNCO’s.
When I was running a unit, my 3 flights each had 3 Corporals, 2 Sergeants and an FS (roughly), if you add in Lance Corporals you just end up not needing the FS.
Completely agree & have been saying so for twenty years. The debate is one here several times so have a look as it might give you some new ideas :slight_smile:
Trouble is that the ATC mindset is try to make cadets now like it was when they were cadets so people do t want to change & we get stagnancy.
The way you propose it is a little Clunky but it reduces the rank congestion & from a policy thing re establishment it’s easy to have the L/Cpl & Cpl establishment be the total number of JNCOs.
The easiest way to introduce it is let Sqn OCs have the option & then let them crack on. If it works it will continue if it doesn’t it will fizzle out with out too much effort from HQ to invest or monitor.
Yeah, I decided to write this and reply to responses during my breaks between classes :sob:
But I couldn’t agree more with what you’ve said.
Having cadet AS2s and AS1s would make more sense: so that cadets can learn (by osmosis, not just a slide they see once during junior cadet training and maybe a — likely out of date — poster) the ranks used across the entire RAF, rather than a rank that’s only used in the RAF Regt.
Yeh, it’d be great to have ranks signifying training competence and then another for “consistently leads by example”.
Currently, for me that one is cdt cpl. but there aren’t enough rungs for a cadet org.
We lose a lot of cadets because they feel they aren’t being recognised by promotion, so anything we can do to have more consistency and rungs would be good in my view.
This is a main reason I don’t have “slots”. If you meet my standards, which I try to make practical and balanced with the wider org, then I’ll promote.
Both these “ranks” are a grade of private & don’t convey supervision responsibilities.
L/Cpl does.
Interestingly the old names of LAC & SAC are part of our cadet classifications of leading & senior so could update those to be maybe part 1, part 2 & advance so that then aligns as different classes of cadets without supervisory responsibility :slightly_smiling_face:
Do we? The only ones I’ve lost in that way wouldn’t have been promoted no matter how many ranks we have.
What rank congestion? We’ve got 5 ranks (if you include cadet) and a maximum of what 7 years, 1 promotion every year with a couple of years as a CWO at the end is not congested.
5 years as the game changes once they hit 18 / school leaving age.
CWO is becoming a non-rank as wings keep throwing in extra hoops for cadets to jump through before they can become eligible.
Congestion around the CPl & Sgt bottle neck depending you are on local policy.
Which won’t change by adding an extra rank, you will just end up with even less Sergeants.
If you have the establishment of JNCOs being LCpls + cpls it makes it easier to bypass blocking Cpls
There’s less of an issue with a lcpl becoming a Cpl particularly if lcpl replaces the unofficial acting Cpl or temporary Cpl thing that some sqns use.
I think Sqn OCs should have it as an option at the very least so it allows for tailoring to specific sqns & specific OC command styles.
