Lance Corporals in ATC
I don’t really see how it makes a difference if you are obsessed by arbitrary numbers as an OC then you will just end up with blocking L/Cpls instead.
Whereas those who are sensible will just go over “establishment” if you have those who need promoting.
Introducing an extra junior rank will just push all the other ranks a year down the line, so we will end up with less FS and CWO’s both of which we don’t have enough of already.
As is every rank up to FS.
Only CWO is a Wing appt.
That needs reporting to regions.
They shouldn’t be inventing policy. If the policy is thought to need improvement, they should recommend formal changes.
Scoffs in CCF and can promote at our wishes
Report what? It’s upto Wings how they select and appoint CWO’s which means they can set whatever standard they see fit.
One of my new favourite lines.
We are only a state grammar
And then there’s the Civil Air Patrol Cadets with 18 ranks, with commissioned cadets going all the way up to Cdt Colonel :joy:
As one RAFAC - introduce it to the ATC and then permit Sqn Cdrs to chose if they wish to implement the rank on their units - merely another option for them.
Interestingly I encountered an excellent ATC cadet at an event on Sunday, and I asked him what he needed to do for promotion as he struck me as an excellent candidate. He said he didn’t know (so I told him to go ask) but I realised afterwards that I would have been looking to make him a LCpl and maybe he was being held back because they didn’t think he was old enough (Y11 I think?) to be a Cpl yet. He displayed excellent leadership in a team activity… Felt sorry for him.
Year 11? That’s Sergeant going on Flight Sergeant age
Got myself confused on two counts there.
I agree and wish we could have lance cpl in the squadron and think it would work well on our squadron
Flash back to 18 year old Cdt FS me when the new OC (previous OC had promoted me all the way to FS over the previous 5 years) said he’d only put me in for CWO if I did the following:
  1. Completed JL - I was an academic teenager, not an outdoors person.
  2. Possess a Wing-level position eg. DS at Wing JNCO Courses.
I fulfilled the 2nd criteria but WSO said I could only continue in the role as a CWO but OC wouldn’t do it until I did JL.
Remember at the time thinking of complaining to Wing Commander but didn’t want to break chain of command.
In hindsight I wish I did. The new Sqn OC could have just been up front he didn’t like me rather than making ridiculous requirements. I’d also highlighted a significant safeguarding issue I was having but since I was “an adult” he didn’t help. He really was a bit of a…
Notwithstanding the Rocks using l/cpl, we ain’t the Army!
I don’t think anyone has actually proved a concrete need for the rank in RAFAC.
It would add another work stream on a sqn for selection too - & ongoing supervision.
For me, not needed - we have a fairly large sqn & its hard enough keeping up with cpl promotions! :grin:
It already exists within RAFAC (& has for a considerable number of decades) the debate is whether the option is given to OC of ATC units :slight_smile:
I don’t think it would - JCpl / LCpl is (from an ATC viewpoint) a pseudo acting Cpl rank.
To me the transition from LCpl to Cpl would be a portfolio / course achievement rather than a selection board like I do for Sgts
Jnr Tech use to be a single stripe & was treated as a LCpl for a while until the change it tech ranks & that it wasn’t covered under QRs. It is the origin of why the CCF initially had JCpl rather than LCpl
Even earlier than that, LAC was considered a junior leadership position (hence the name) — comparable to lcpl (although never actually considered an NCO).
If LCpl was implemented in the RAF Regt to help with “translation” when working with the Army (a former Rock Ape I know explained it as “the Army couldn’t understand how someone who wasn’t an NCO (eg an SAC) could lead or support a Section”), then I’d argue that unless we’re working with our Army equivalent (ACF) on a very regular basis then there’s no need. If we’re just meeting them at the odd fundraiser or parade, the NCO ranks should be obvious.
However, the CCF who have several Sections of different uniforms, cadet services and ranks at their parade nights/days, probably need that parity much more regularly.
I’m sure there were plenty of other reasons to bring in LCpl so I’m not suggesting the above is the only reason!
So just give them Cpl rank? Or ask them to act up as a cadet?
We don’t need another rank to designate that a cadet isn’t a Corporal.
There’s also been suggestion above that it be made available and then be up to OCs if they use it or not - what’s the point if it’s not going to be used? Surely we need to standardise the cadet experience rather than add in more local variation.
What is the obsession with acting ranks? Just promote people and be done with it.
