L98A2 Cleaning
If I may…
The previously discussed TG Letter gives authority for the use of Rifle Lesson 3.1.
Rifle 3.1 requires the Load to normally be carried out in the standing position. It goes on to say at para 195 that if the cadet/CFAV is required to load in any other position, they will first be ordered into it.
The WHT stipulates “Adopt the Prone Position”, followed by “Load”. As everyone that conducts WHTs should know, the WHT is a laid-down minimum standard that should not be messed with, ergo:
Cadets should normally load in the standing position. In the WHT, they should load in the prone position because that’s what’s required by the test.
Where’s the confusion?
On a separate note
I understand that the establishment of TG Letters is intended to address some of the issues with the dissemination of policy in the shooting/TG world. I believe the intention is to reduce the need for absorbing policy by osmosis, as mentioned earlier in the thread. I’d hope that TG letters will be backed up with CROs and emails going forward.
The confusion I believe lies in the comment on SharePoint, presumably made by the HQAC TG staff who posted the new Lesson 3.1 (and we have already discussed whether a comment made in this way has any clout as policy) which says ‘This version, Lesson 3.1 replaces the original Lesson 3 in Pam 5c. During WHTs (see Pam 21c Chapter 5) drills are to be carried out as taught in Lesson 3.1’.
FYI, the new Pam 5-C now contains the WHT and the load is done in the standing position but the ready is done in the prone.
Has been released to the ACO?
To the ACF and CCF. I assume you will receive it shortly as it is the only official CF manual for the L98A2 and L86A2.
To the ACF and CCF. I assume you will receive it shortly as it is the only official CF manual for the L98A2 and L86A2.[/quote]The version currently available on BADER is dated March 2012…
We should be due for a new 21-C as well. Was due out yesterday.
We have that too.
Cracking.
Is this a surprise? I had to put in a request to HQAC via the change requests IIRC to get the e-copy of PAM5C when it got reduced to PROTECT.
My Bader alerts tell me that they’re both on Sharepoint now.
They certainly are.
Spooky…
Did you get the changes document too? It looks to be ACF/CCF specific, but is useful.
Nope - not seen a summary of changes.
Besides, the whole manual looks to be ACF/CCF specific with the “oh and whatever the others do” thrown in :wink:
Since it is not protectively marked, and I am feeling helpful, here is a summary of the main changes:
Rifle:
[ul]
[li]Tap forward now specified for NSPs[/li]
[li]Functions test no longer has to be done in the prone position[/li]
[li]Added the updated rifle lesson 3[/li]
[li]Adopting the prone position is taught in rifle lesson 5[/li]
[li]Firing from other positions is now rifle lesson 8[/li]
[li]The standing position is now taught as part of firing from other positions[/li]
[li]Use of cover now part of rifle lesson 8[/li]
[li]Mechanism of the Weapon, Immediate Action and Stoppages is now rifle lesson 9[/li]
[li]Checking the safety catch is no longer required as part of the IA drill.[/li]
[li]New rifle lesson 12 - Firing at Crossing and Multiple Targets[/li]
[li]Added a specific lesson on boresighting the rifle with iron sight[/li]
[li]Added a specific lesson on zeroing the rifle with iron sight[/li]
[li]Added a lesson on the L41A1 sub calibre adapter[/li]
[/ul]
LSW:
[ul]
[li]NSPs now taught and carried out standing[/li]
[li]Stripping and assembling is now LSW lesson 2[/li]
[li]New LSW lesson 4 - Alteration Of Sights, Selection and use of Firing Positions[/li]
[/ul]
WHTs:
[ul]
[li]Weapon Handling Tests are now part of Pam 5-C[/li]
[li]Loading is now done in the standing position[/li]
[li]The time limit for magazine filling has been removed.[/li]
[/ul]
seems like some siginificant changes there
nice that the prone position for the function test has been removed
para 01145a doesnt really cover how to “adopt the prone position” only what is required (hold the rifle steady, keep it pointing in the safe direction, lie down on the ground) - doesnt really offer much of an explaination
why swap lesson 8&9 around?
i can see the thinking behind removing the SC in IA drills to bring the drill into line with the L85…but why was there in the first place if it is now deemed a pointless action?
and the tap forward on the NSP will be an interesting change. i didnt teach it in Lesson1 and was quick to jump on any instructor who repremanded a Cadet for not tapping forward on the NSP…the same old argument came back “yeh but it is good practise”…true, but didnt excuse the instructor for not knowing the PAM. now we see a reversal of that.
It frustrates me that intructors will now be right through ignorance rather than due diligence and integrity of knowing the PAM.
Personally i thought it made sense to me, why tap the cocking hand forward to ensurance it correctly seated if there is no intention to fire a round…?
i know of plenty of WIs who will be glad to see the 10rds in 20s gone…but why go as far as 10? what does filling with 10 rds prove that cant be done with say 5…or even three rounds?
given the changes can anyone predict the “conversion” requirement for those who have already passed under the old system?
or is a quiet word prior to their re-newing WHT:
dont rush the mag load, there is no time limit
you should now make sure you tap forward on an NSP
function test doesnt have to be in the prone position
no need to check the SC on the IA drills.
its almost enough reason to re-teach, or at least have a “conversion” course given the variation in drills.
i’ve met enough Cadets who are confused enough by the L98, rattling through that prior to a WHT will only confused them further i am sure!
[quote=“steve679” post=10714]
why swap lesson 8&9 around? [/quote]
Lesson 8 (firing from other positions) will now be taught to ACF cadets at 1* level, whereas it was 2* before. I guess they put it before ‘Mechanism’ to show that it should be taught prior to undertaking the WHT. They haven’t said whether or not they will change the 1* assessment as well (currently just a WHT).
Someone being “over safe” probably.
Ditto. it makes things simpler but is kind of annoying at the same time. I still have those doing 7 point checks on NSPs to pick on though!
[quote=“talon” post=10715]
Ditto. it makes things simpler but is kind of annoying at the same time. I still have those doing 7 point checks on NSPs to pick on though![/quote]
and “hook, cock and look”
