Trying to sort out our indoor air rifle range at the unit. We’ve had pre-inspections and there is a fair few bits that need covering down range. Doors/windows/radiators metal etc etc. We recon a big wall oh hessian is likely the easiest way forward, but can’t find where to source it from! Any help would be appreciated.
Very interesting! Not seen this before and our TSA only mentioned hessian. Looks good though. We were hoping for something in a 2.5m roll but this could be made to work
When we ordered it it was 1.5m wide and you could order cut panels. Our go to was 1.5x2.4 (floor to roof) and overlapped by 6 inches each time! We had 10 panels and got a parent to hem and stitch on velcro as needed…
Not him, but the TSA extensively as to what we need to do to get it approved. Currently just a cae of sourcing materials to get it done! We essentially just need to remove any possibility of a ricochet. We could build little wood boxes around things but that seems like a PITA so we’re planning in a big ol’ wall of hessian. (Or this ballistic fibre stuff now!)
That ballistic stuff is good, I’ve been to a few ranges with it on now and it’s easier to work with than hessian, lighter for hanging on curtain rails to run it in and out. It is an expensive solution though.
We’re currently finishing off our TS25 indoor range, but our directive from TSA was to use 5mm plywood for side and 10mm direct line of fire. We’ve had to build boxes for all sockets, radiators and about to start on the double fire exit doors. There was no mention of using any other materials, as ballistic nylon would be really good option for the fire exit doors.
So this is what I read in the JSP, and also what I’ve seen some squadrons do. But we queried this due to the amount of work it would require and were told hessian would be a fine alternative!
We’re hoping to not have to go down the wooden box route! This nylon stuff sounds like it’ll work well for us. Maybe make up some kind of curtain rail for it.
RC LaSER as DDH has made an exception that if a med mod 069 isn’t available then a ‘medium work place’ first aid kit confirming to BS 8599-1:2019 is acceptable for air rifle only.
Obviously this only applies to LaSER but I’d be surprised if other RCs had not made similar decisions.
