It’s been 8 or 9 years since I did mine. Then, the first day was a written test, uniform inspection, revision of Flt and Sqn Drill, Wing Drill, Qualities of a DI… that sort of thing.
Tuesday we were told which movement we’d be teaching (it was either a turn on the march, or change step, in quick time).
Tuesday, Wednesday were spent preparing our lessons in syndicates as well as filler activities such as closed stick drill, Banner drill, changing from slow to quick time…
Those who were ready were assessed on Wednesday afternoon, the remainder were assessed throughout the day on Thursday.
Friday morning was a written test, certificates, course appraisal, then home.
It was a great week! I found it to be a very enjoyable course. Having been told by colleagues that it was the toughest course they’d ever done I was more than a bit nervous. When it came to it, I didn’t actually find it particularly difficult.
Fortunately I have a head for remembering, so once I learned the drill mutual verbatim (before I went) all I had to do was focus on the demonstrations and just keep doing it.
Pre course preparation definitely helped! Memorising the parade diagrams was a must.
If you know you’re good at drill and you can learn a script you should be okay.
I am told that the course has been tightened up since then and the standard raised, which I think is a good thing!!
My tips would be:
[ul]
[li]Ensure that your personal drill is top notch.[/li]
[li]If you can learn the drill mutual wording before you go (they used to provide it with the JIs), so much the better.[/li]
[li]Learn parade layouts - locations of Execs and Supernumeraries for Flt, Sqn, Wing drill; layout of parade square, etc.[/li]
[li]Practice stick drill using a stick, umbrella etc (I was amazed at how many people on my course couldn’t keep the stick parallel with the ground when marching at the trail).[/li]
[li]Ensure that if you pass you come away and keep learning. Whilst you’ll be qualified as a DI, you’ll be nowhere near the standard of an RAF Q-DI. If you want to be credible, keep working on it.[/li]
[/ul]
