I have found out that it has been for all MoD activities for over a year. As usual the SLT of RAFAC were seriously behind the curve on this.
From what ive heard, they may not have actually been informed.
So we’ve now been told that all adults must do Module 1 and all adults who will be in positions of command where there is a risk of heat illness must also do Module 2. I only see module 2 on ultimate though (Lessons 3 and 4). No module 1. Also, what about if we’ve already done it on DLE; Do we now need to do it again on ultilearn?
Send WHQ your certificate and say you won’t be duplicating the training.
I don’t think I ever saved the certificate when I completed the course
But I’ll have to have a look. Maybe some screenshots showing the course as complete might suffice.
Fingers crossed for you!
Login to Defence Gateway, go to DLE and then under My Courses in the right hand menu you should see the heat illness prevention course. Select the module and you should be able to get the certificate ![]()
Is anyone else having difficulties accessing these courses on Ultilearn? Just won’t load at all for me (not really surprising, its ultilearn but just curious if its a wider issue this time)
I’ve not tried, but what I have seen as mentioned above is module 1 is completely missing, only module 2 is on there.
registered on Ulitlearn, wont work; used the link from above in this thread able to do Mod 1 and Mod 2 on DLE - took about 3 hours.
Nothing seen here about needing to do the heat illness prevention course.
Was this sent out by SharePoint Announcement, Email, IBN, Facebook, or Telepathy?
Email. From HQ to all HSAs/TSAs by the looks of it.
yep email to TSAs from HQAC then from them to us in LaSER
Handy Guide on how to access the Preventing Heat Illness training on Defence Gateway
#hero
And words.
Doing it at the mo…this is actually what training should be like, im actually engaged, albeit have to break it up now and then
Thank you - I had actually given up trying to get registered until I read that!
So due to RIAT successfully raising the heat injury stats there is now another form generated on top of the normal accident form, glad their RA was so successful on coping with the heat whilst everyone else heeded HQRAFAC dvice of stay in doors or cancel ![]()
Only for national camps it says.
Where’s this?
