Congratulations to Gp Cpt Pass (for 2 weeks time) I think this is a positive step and brings someone of equal standing to the RCs onto the Command Board to speak from the Volunteer Perspective.
It’s another route for OC Wings other than Region Aviation / Region Senior Staff Officer other than retirement onto CivCom which is the other common route.
That does seem like good progress in getting volunteers’ voice heard at the right levels. I assume Gp Capt Pass is an ex-Wg Cdr? The IBN could have provided a bit more about their background.
This is a very positive move. Good to see the commandant acknowledging volunteers and their input at the highest levels, and good the the wider RAF/Reserves agreed to it too. Good move!
This is a good change as it improves the rank structure.
I too was under the impression that it was a written rule that the highest volunteer rank could only be Wg Cdr. Maybe this was removed with the CFC? Anyone have info.
Couple of points…
I see he is “acting gp capt” is this because its not substantive yet or because its acting unpaid?
The ibn made no reference to term of appointmen. This will be interesting to know. Bet there are a few miserable Wg cdrs this morning!
Likelihood of this becoming a regular thing? More than 1?
Hope he does a good job… positive steps towards removing some dead wood this way.
Wonder if location in relative proximity to Cranwell was a factor… cant see a Wg cdr in highlands being appointed…
I suspect that’s because we are all substantive Plt Off or Fg Off and everything above that is acting.
It probably also helps with the comms to the wider RAF that this volunteer post is ‘only acting’. An appointment as senior as a Group Capt RAFAC will probably raise a few eyebrows.
without knowing / understanding the legalities, I’d expect that the RC / COS are defined as being RAF/RAFR, and if our substantive ranks are only FO could one transfer their commission and get an immediate 4 rank promotion?
It’s the duty holder element that would prevent CFC doing it… Their head can be on the chopping block under military law where as CFC can’t. It would mean making it a VRT role, but given we do that for AEF means it isn’t out the realm of possibility
