Uniform demand spreadsheet
I used to have a useful spreadsheet which generated stock numbers from an input of item and size. It also generated the demand sheet that could be sent directly to stores.
Does anyone happen to have a copy they would share?
thanks
rich
I have sent you a message about this. There is one buried on SharePoint which I have downloaded for you.
tkg, any chance you can send me a link to that too? At the moment I have a spreadsheet but anything I can do to speed things up would be good.
Sure. Don’t know if I’m allowed to post Bader links, but you can access it here:
https://sharepoint.bader.mod.uk/CCF/TESTE/Shared%20Documents/Resources/Clothing/20141006-Uniform%20Demands%20Spreadsheet%20V5.2-SNCO.S2-U.xlsx
It’s for the CCF, but populates the form that we use, and is easy to adapt. One the one i’ve attached, just add your Squadrons name on the first page.
Thanks all - much appreciated
If the sizes of cadets are put into SMS, the system give the correct? stock codes for items to be ordered. The ? is that I assume any new codes are put into SMS but from the email earlier today maybe they are just put into a file.
Some of the codes on SMS are incorrect, i was doing an order last night and the Jumpers i think don’t match up with the codes from our stores.
I asked HQAC if SMS was up to date and they thought some NATO codes had changed. Response I got was, use what is on the system and someone will translate.
I asked them to update when available.
There is a SR in the system 16700 to get it reviewed.
