I just think we need to remove as much CI vs Uniformed barriers and have the right people hold roles regardless of what colour uniform at the end of the day.
And thats coming from a drill monkey! Id let a CI teach drill if it was taught correctly.
This is, as highlighted by others, perceived as a “sub-optimal” decision. If the logic & background processes to this decision can’t be explained on this forum (& I see no reason why this isn’t possible), then a formal notification needs to be issued so that CFAVs can understand why CIs are being blocked off.
Has anyone actually asked yet on Value our Volunteer to challenge this yet?
This then give the issue wider awareness on formal channel, requires a formal response from the decision maker, & maybe gives @Hercules the evidence & the hook to challenge things higher up the chain.
But until someone does we just put Hercules in the situation of saying “I can’t comment on this as it’s not a formal military channel “ hint hint
It’s not for that risk. Look at the RA which is on the 2 FTS website. Having worn them for many moons whilst using police drones, it wasn’t for that there either.
MTP is being using to mitigate another risk on the RA in relation to a specific drone. As only instructors will be using or demoing this, only they need to be willing to wear it.
It’s part of the hand launch and recovery ppe requirements. But as we’ve trialled the courses and limited flying, we don’t see a need for this, so it’ll disappear at the next manual update.
MTP is for another reason and that is an activity that’s not taught by the third-party on these courses, hence civvies. But will be required for RAFAC use and will be covered as a bolt on.
