Tri Service Cadet Forces Heat Illness Policy [Published to RAFAC 26 June 26]
New Heat Illness policy on SharePoint - applicable to all cadet forces (no change to cold policy)
Haven’t had time to read it in its entirety yet, but greater alignment across the cadet forces and the comms on this being quite good (briefing announcement, and one-pager what you need to know summary, and actual policy doc), so I’m optimistic.
I will admit the timing of a policy overhaul mid way through a heatwave is… tricky… for any activities going ahead this weekend though.
Ok, that’s good. But nothing sent by email or Teams either direct or through CoC.
So once again learning of new policies here!
I did have a teams notification about it, but I realise now that’s actually probably because I’ve subscribed to the newsfeed… I’d hoped that would have gone to everyone but alas..
Launched in the middle of a heat wave so probably make sense to keep everyone currently on the current process and have notifications highlighted in mail drops.
Policy effective immediately from 15 Jun.
So it’s still taken 10 days to not reach us.
I did have a subscription to SharePoint updates. But not sure if it is still working.
It’s something that shouldn’t rely on someone finding it and posting it on a forum!
So I’ve completed a cursory look though this, and actually it’s a good policy. Typically let down by the communication of the policy.
MOD RF&C Safety Notice published 15 June 26
Here we are on working day 9 publishing it to the organisation, at lunchtime, on a Friday, just before AFD Weekend.
And by publish, we mean dump on SharePoint, as unless you are “Following” the RAFAC HQ Site you have no notification of news being published.
Interestingly, unlike the Red Heat Alert communications that have been sent to all, this change of policy isn’t deemed worthy of that communication level - whilst staffing for MACs has been sent by email twice.
I’m usually against direct emails, but this should clearly have been included in the Red / Amber heat comms that have been going out anyway.
Maybe the fact that it is wasn’t indicates that RHQs aren’t even aware of it?
HQ staff probably sent home as too hot to work to publish a new heat illness policy which could have been ideal before the impending heat wave!
A tri-service cadet forces policy eh? Written sensibly??
Maybe what we actually need is a tri-service HQ to write all policies… with a single service figurehead to champion the cause… and nothing more…
You know, like what Brigadier Plastow wrote in DYER in 2011…
So interestingly the new policy makes not reference to the met office of health & social care alerts
Does this mean that the heat alerts escalation for region sign off etc is done on the matrix instead?
I’ve not had any view of this new policy. Is it in place of the existing heat policy? Does it override it or is it subservent to existing policy?
Keeping Our Cool: New Tri-Service Cadet Heat Illness Policy Launched
^ Link to the new policy being launched - Posted 3 Hours ago (~1215) and has 213 views.
Within that article is a link to the Safety Centre Hub - Tri Service Cadet Forces Heat Illness Policy which has been updated from the previous content - which I was actively reviewing yesterday.
I can’t find it on T&A, so that’s helpful.
My understanding is that JSPs, DINs, etc, take precedence over APs, ACPs, IBNs, etc, but don’t necessarily supersede them (as sS D&G can refine, but not contradict, joint policy).
One advantage of this new matrix is that is uses the met office app & reduces the needs for Momids.
It also means exact location can be used & you can adjust for the day so it enables quick risk assessment
we were due to have an AFD tomorrow with recruitment stand.
So
intensity = sedentary = 1 pt
Met Off UV = high = 3 pts
Met office feels like = 25 =4 ptS
Total = 8
that’s in the amber for the mitigation risk so up to region for approval.
because it’s the app can do this a week in advance giving region a fighting chance to approve in time.
if I’d did the event next the app is showing UV would be moderate & Temp would be 17 initial but high & 19 later on.
So 4 (green) initially but 6 (yellow) later on so still okay for local approval.
however if I were going to have a marching parade that would be an increase intensity pushing it to a 7 & amber which would mean region approval still needed even if no heat alerts.
This seems a better way to work things as it means the MoD & cadet forces are not dependent on Met office heat always or the even more generalised health alerts (which aren’t designed for us but for hospitals & care homes)
you can also apply this to Sqn parade nights to adapt to change of circumstances to change activities.
So overall it works & allows more planning time so it feels really useful.
It also means region hasn’t got to approve everything so increases capacity.
Yeap - the use of “Feels like” rather than pursuing Momids so you don’t need a degree in meteorology to understand what’s going on.
(Not sure whether ACF or SCC colleagues had access to the full Met Office suite anyway??)
Also quite liked the definitions embedded in the Annex’s - “You are doing this activity type - if you are doing it this way it’s sedentary, or that way is more effort, so more intense”
Then cross reference back to the mitigations and go/no go document.
A MUCH more straight forward method of working. AND subsequently reporting via the after activity report.
My understanding is that they specifically told not to & stop using WBGT as it couldn’t be applied to young people.
You mean like the organisation was told in the independent review into RIAT that was released before we then introduced WBGT and work-rest tables?
Is there anything in this new policy people think doesn’t work?
anything we can poke holes in?
Or will it just be the concern that rafac try’s to keep to its old system as well as the new one?
I quite like it so just trying to avoid halo effect
