I came up with this some time ago, but Incubus’ Radio Comms thread reminded me of it.
- Current issues. As I see it, there are a number of issues with our classification training syllabus as it stands:
a. The point. Nowhere in any of the articles which define the point of the ATC/ACO can I actually see anything which says that a significant proportion - if not even a majority - of our time is to be spent doing academic training towards a BTEC qual. Don’t get me wrong, I’m all for formal recognition of what we do - but the tail increasingly seems to be wagging the dog in regards to the BTEC qual - and academic training is not really what we’re all about anyway. None of the three aims directly correspond to academic training - the closest we get is “skills useful in service/civilian life” which is highly questionable above first class to say the least, and “practical interest in aviation and the Royal Air Force” in which our syllabus misses the practical part and pretty much anything in the RAF that isn’t flying. Whilst first class training is required - and quite rightly standardised - for the cadet to be able to ‘operate’ in the ACO, at higher levels (basic nav excepted) the subjects are essentially taught for interest; cadets are unlikely to make practical use of the subjects during their cadet career.
b. The narrow focus. The cadet forces are best set up to deliver so-called ‘soft-skills’; leadership, teamwork, self-reliance, confidence, etc. Compared to academic training, we are better placed to deliver these, they’re more fun (crucial in a voluntary youth organisation) and don’t just replicate what cadets do in school anyway. However, our classification syllabus - a cadet’s main means of measuring progress - simply doesn’t cover these at all. We don’t even have a leadership theory subject!
c. Over-complicated and misdirected First Class training. As has been pointed out elsewhere (including at the link above) much of our first class training is either out-of-date, over-complicated or focussed on unimportant details to the detriment of core principles. For example, looking at the first class logbook, in Airmanship cadets are expected to name the arrestor gear and sterile areas on an airfield as a mandatory, pass criteria but what control surface actually affects what plane of movement in an aircraft is considered an extra, merit criteria and the throttle is not mentioned at all!
My suggested changes:
First class:
Replace Map reading with basic nav (a composite of parts of current map reading and basic nav)
Radio comms reduced in scope (remainder moved to leading cadet subject)
Airmanship - stripped of most airfields knowledge and replaced with basic PoF.
ATC, IET, RAF and HF – remain roughly unchanged
Leading:
6 subjects -
Basic Leadership theory (the Air Cadet Leadership Programme would be a good basis for this)
Advanced ground nav
PoF
AK
Radio comms (intermediate)
(additional subjects – see below)
Sen/Mas:
6 subjects -
Current subjects +
RAF Regiment
RAF Fire service
Logs
Medical
RAFP
Advanced leadership theory
Additional subjects:
Additional weapon type - 1 subject (1 per level, additional may be saved up for next level, eg completing no8 before first class and l98 before leading would give 1 extra subject at leading and one extra at senior)
Marksman: sqn at ldg, wg at sen and reg/corps at master (higher levels count at all levels, eg passing wg before ldg would give 1 extra subject for both ldg and sen
Leadership
Leading - Weekend wing/sqn leadership/NCO course - min 12 hours training time
Sen/master - ACLC, CLC, JL, QAIC
Camp:
Ldg - attend RAF annual camp
Sen - attend as JNCO
Master - attend as SNCO/WO
Flying:
Sen/master: GS/FS
First Aid
Ldg - YFA (AFAIK it’s already corps policy that YFA should be taught at leading level)
Sen/master - AFA/FAAW/NPLQ/etc
- Rationale. The above would mean that the points would be addressed as follows:
a & b. Soft skills and “practical interests” would primarily be recognised by the use of the “additional” subjects (shooting, camps, flying, etc) and – in the case of soft skills – by the addition of leadership teaching. Wider RAF knowledge would be covered by the additional senior/master cadet subjects.
c. Addressed by changes to the first class syllabus
Comparison to current training. This would not necessarily lead to the requirement to massively change training for everyone - for example, completing first class would remain much the same, and if a cadet did
Principles of flight
Airmanship Knowledge
Intermediate radio comms (currently covered at first class, but a similar subject)
Advanced ground nav
Youth first aid
and attended an annual camp, then they would pass leading - much the same as the current situation. However, the training syllabus to leading could be significantly diversified where possible and desirable. -
Compatibility with BTEC. Considering that the subjects should remain similar, I can’t see any issue with award of the BTEC for someone who completes 9 (or possibly 10 considering the splitting of radio comms) academic subjects. If a more practical path is followed, then this may not be compatible with the BTEC, although there is no reason why additional ‘top-up’ subjects could not be taken at master cadet level to fill the required quota if this turns out to be the case.
Thoughts?
