Am I right in saying you use flight if it is 12 or more??
9 or more off the top of my head but itâs quite a while since I last delved into 818, @AlexCorbin will know for sure
I had to check as I had forgotten (Iâm dissapointed in myself and will be having a word) and without going through the entire 2000 times the word squad or flight appears I referred to the glossary of terms âŚ
Squad - A small body of personnel formed for drill or working party.
Flight - A sub-unit, 2 or more of which comprise a squadron. Equates in size approximately to a naval or army platoon.
Depends on the context⌠For drill practice itâs probably right to use Squad but on ceremonial occasions where the Sqn is split in 2 for 2 flights Iâd use flight.
But 9 has always been a rule of thumb Iâve heard
Alex has pretty much hit it.
9 persons is a commonly touted âlimitâ but in actuality there is no number; itâs more a case of context. If youâve got a group out doing drill they are a Squad.
If you have a formal sub-unit on a parade then they are a Flight.
However, if you are out practicing drill with just one of your multiple flights then there is nothing wrong with calling them âflightâ; but you donât need to just because youâve got lots of them.
Itâs just one of those fads that has become common⌠Another similar one is the idea that you form in 2 ranks with 8 cadets or less, but 3 ranks with 9 or more. That might be where this squad/flight ânumber limitâ has come from.
In truth, again, there is no specific number below which you automatically form in 2 ranks.
This is in the notes to âGet on paradeâ in AP818 - is the intention to form 2 ranks only for this command and itâs been misinterpreted?
- If there is less than nine persons to form a squad, they are to be formed up in two ranks with the same intervals between individuals as described.
No, thatâs true actually. I had forgotten about that.
I had my mind elsewhere - That our first and final âparadesâ arenât really parades. They are really just musters, and it doesnât really matter how you put them together to call a roll. Iâm rarely even bothered whether theyâre sized for that. Weâre not doing drill, weâre just standing in the hall. I normally just call âFall in!â and they get into a small squad.
The common cadetism is that if there are 8 persons the cadets are supposed to just know and automatically form in 2 ranks when sizing. Of course, âsizing a squadâ does not give any other drill than to form in three ranks.
Personally, I would always size them by the book (in three ranks) and then put them into two ranks as needed. It doesnât really matter - but I like âForm Two Ranksâ
Itâs on my top 5
Somewhere behind âLeft/Right Formâ obviously.
Love minds exploding when you throw that one in there
Almost as crazy as a left dress without intervals
I bloody love a good form. Itâs right up there with âon guardâ.
Ah, now, see⌠Left dress is confusing for many because they rarely get taught it (everyone should be).
But it is at least logical enough to deduce. Look left, use your left arm.
Now, right dress with rifles at the shoulder on the other handâŚ
Have you read Siegfried Sassoonâs âMemoirs of a Fox Hunting Manâ?
Chapter one in particularâŚ
Nope
But will have a nosey
So, when do you use âHalf Flightâ?
