[quote=“bti” post=20148][quote] Gunner wrote:
[quote]Verges wrote:
The Cmdt favours SNCOs in the VR(T). The hold up is that similar internal transfers are required to happen in the other cadet organisations before it can happen in the ACO.[/quote]
Do you have a reference for this? Policy document perhaps?
I find it a tad strange that the Commandant should choose to go down the road of bringing SNCO ATC into the VRT if she knew that there was something that could prevent her doing so.[/quote]
The Defence Council (so, the Air Force Board in our case) has the authority to decide policy and regulations in respect of the Reserve Forces - and presumably each sSvc decides it own policy/regs? - under the authority of Section 4 of RFA96:
[quote]RFA96 Section 4 wrote:
4 Orders and regulations concerning the reserve forces.
(1) Her Majesty may, by order signified under the hand of the Secretary of State, make orders with respect to—
(a) the government and discipline of any reserve force; and
(b) all other matters and things relating to that force,
and including any matter authorised to be prescribed by any provision of this Act or expressed to be subject to orders or regulations under this section.
(2) Subject to the provisions of any order under subsection (1), the Defence Council may make regulations with respect to any matters relating to any reserve force, being matters with respect to which Her Majesty may make orders under that subsection.
(3) Orders or regulations under this section may make different provision for different cases (including different forces), and may include such supplementary, consequential, incidental and transitional provisions as appear to Her Majesty or the Defence Council (as the case may be) to be necessary or expedient.
http://www.legislation.gov.uk/ukpga/1996/14/section/4
[/quote]
So - under the authority of RFA96 Section 4 sub-Sections 1-4 - the AFB can decide policy/regs in relation to the Reserve Air Forces (i.e. the RAFR - inc. the RAFVR - and the RAuxAF) …which of course includes RAFVR(T) T&COS in AP1919.
The only issue I can think of, is that if the Defence Council collectively has decided that CF policy is now - post DYER - to be “joint” via MOD Reserve Forces & Cadets Division (who, of course, are pro-the DYER agenda - and under the direction of VCDS …harmonisation of CFAVs T&COS was of course a key recommendation of DYER, so this is bound to be a sticky subject; and sadly that probably puts it well within the scope of RF&C Div, as opposed to the sSvc COC)
As I see it - unless there is Joint vs. sSvc CF politics at 4* level within the Defence Council (!) - the process is simple:
- SNCO/WO(ATC) re-muster approved by Comdt AC, AOC 22 Gp, Deputy Cdr (Personnel)/AMP at Air Cmd; and then the AFB & CAS.
- RAFVR(T) AP1919 T&COS re-written to include SNCOs & WOs.
- ACP20 etc. updated accordingly.
- Changes go into effect from stipulated date.
Simples.
Personally, I think the best opportunity for this to go ahead with little/no opposition from the Army/MOD was missed back in 2007/08 when Gordon Moulds was Comdt …there was serious talk of it being considered back then, but I - personally - believe that he was badly advised by his own Staff Officers, and the issue was kicked into the long grass. Now CFAV T&COS are seen by the MOD through the prism of DYER, I suspect the sSvc route the RAF seems to want to pursue has become significantly more difficult unless there is some serious medal-rattling at 4* level.
Cheers
BTI[/quote]
Couple of points though, BTI.
First, Verges has alluded to other CF having to ‘integrate’ their SNCO cadre [I]first[/I] before the ACO are permitted to follow suit. That doesn’t make any sense as what gives other CF’s the right to do it but not the ACO? He still hasn’t given us a source to underpin his comments.
Secondly, with the above in mind, surely all three CF’s do it simultaneously or none do it at all?
I’m still puzzled as to why the Commandant has chosen to go VR(T) for all staff if she knew there were issues surrounding her doing so. Either she’s been as badly advised as Gordon Moulds may have been or maybe all 3 CF’s are actually heading in the same direction?
Of course, it might well be that that the RAF don’t wish to implement some of the DYER recommendations in relation to CFAV TCOS and want to go their own way? I can’t see a 1* trying to implement something that has very wide-ranging implications if she didn’t have support as far up as 4*…
