Return after Covid
Can anyone clarify the return to a unit after having Covid - should it be (a) after two negative tests, or (b) after completing the government limit for isolation and having no symptoms but still showing a faint positive line?
Testing is not mandated as they are now not free (unless you are vulnerable).
I’d say the prevailing wisdom is as per the government guidance:
https://www.gov.uk/guidance/people-with-symptoms-of-a-respiratory-infection-including-covid-19#what-to-do-if-you-have-a-positive-covid-19-test-result
I’d suggest if you are still testing positive then hang off until the 10 day point as you don’t know who might be vulnerable at the unit.
Thank you, I was just about to ask this question.
