Maybe something the new Senior CFAV can push !?!?
or rather than finding solutions to problems that shouldnāt exisit - remove the need for AO for events held at a Squadron building?
while the solutions sound valid, why go to all that effort when the real solution is to remove the problem altogether.
As @pEp indicated - events held on a weekday evening need no paperwork, yet hold them on a Saturday morning and they do - for no reason given there is no increased risk of anything.
so why find way to make the AO work, when it shouldnāt be required in the first place?
or am i sounding too sensible?
I think the terminology will move from ASTRA to SDR 2030.
Iām not for one moment suggesting that AO/JIs should be required for an on unit classroom activity. What I am saying is that when AO/JIs are required (by DTE, MT, etc.) then it should be a click of a button rather than a mandraulic process.
This.
If we want SMS to have event management it really should actually help planning. A wizard of sorts that then generates a auditable, standard compliant set of documentation
Given that weāve been told SMS is being turned off for what, 5 years now? I canāt see anything actually happening with it. And now that the person managing the volunteer software team is doing other stuff I donāt hold out much hope.
Remember that the VSDT was disbanded years ago and folded into the main RAFAC Digital Team.
Yes one of the team members has just been appointed to another role, but there are others in the team too.
And in the recent townhall CAC indicated he was able to hire some contractors through RFCA.
Now thatās the sort of action we need from our CAC. Get past the CS nonsense, and employ some people!
Evening folks, just been reading through some of the comments on this thread, thank you for tagging me!
Some really interesting points showing inconsistencies across the organisation, clearly it is too early for me to have answers yet, but Iāve added them to my list as I start my engagement.
I can provide some points relating to what RAFAC Digital are doing in this space though that will help in time. The āSMS to Portalsā project as we refer to it internally has obviously been going on for some time, the launch of Volunteer Portal and Admin Portal was the very initial launch of the project, the team have a whole feature map that is being used to track SMS features and there rebuild in new platforms. Of course, we try where possible to refine process wherever possible rather than just lift and shift.
Events is a huge piece of work that is going to require a complete rework, the organisation has moved on hugely since the current events module was written for SMS.
Events will ultimately become a complete event planning tool (incorporating CACE) as well as the approval and post event management tool. As part of this, it will look at collating all of the necessary data involved in planning the activity so that rather than people having to go off and write AOs, JIs etc, where itās necessary, it has the information and can then produce a document for you if you need to send it to MT etc. This of course needs to cater for everything from a weekend activity at the unit, to large multi activity camps etc, so lots of thought going in to the architecture to ensure it is both simple to use and scaleable.
I have no doubt that the team will continue to produce great work, they did great things before I became the OC and they will continue to do after a move on, of course Iāll continue to be in regular contact with them because I know they can deliver so much that support volunteers across the country and they are an incredible example of what aligned CFAV and Permanent staff can deliver and that is primarily down to the enablement by the Head of Digital and RC North.
Do you know what the future is for CCF event management? If CACE is wrapped up into SMS, then does that mean CCF will need their own parallel process (as eg we have with VA)? The idea that it generates AOs etc is awesome, though, so it might actually be less work to create the event in there anyway as well as Westminsterā¦
The Cmdt at the recent Town Hall was also talking about the idea that Bader might become a tri service system . . . There certainly would be advantages to everyone using the same system, although whether it should be bader or westmister is obviously debatable.
Thereās been another thread on this - opinion divided but most of those who have used Westminster prefer it. (Might just be Stockholm syndrome.)
If it doesnāt log you out after 5 mins (like Bader), or run slower on parade evenings (when you need it to be quick, anything gets my vote! ![]()
Iām not aware of any planned change to activity planning and approval currently. But the team are working with the Westminster team to expose event data to the API so that we can then apply the same digital process for CCF CFAV Volunteer Allowance claims.
