[quote=“Chief Tech” post=13913][quote=“juliet mike” post=13910]As is stated above, the safety catch makes no difference during the stoppage and IA, the weapon will not fire, which is why it is a stoppage.
A safety catch is not applied during a stoppage on a .22 rifle during a stoppage (misfire etc) so why should it be required.
I think and fell, from my experience, that this magical Safety Catch on the L98 possibly gives cadets a false sense of security. They should be thinking about more than whether it is at S or F.[/quote]
The safety catch on a No 8 doesn’t make a difference as it prevents the bolt operating and the firing pin has already gone forward.
However with the L98, the safety catch does stop the weapon from firing whilst clearing a stoppage i.e. working parts go forward when the cadets finger is holding onto the trigger = Instant bang*[/quote]
Interesting. You shouldn’t be able to do that with any SA80 series weapon (A1 or A2). The only way I can think of to achieve that is to operate the cocking handle manually to get a round fed from the magazine but without going back far enough for the safety sear to lock the hammer. And that would be an obvious design flaw, so I wouldn’t expect that to be physically possible at all!
As for safety catches etc - from a mechanical point of view, the safety on the SA80 achieves nothing other than to stop the firer from being able to fire the rifle conventionally. If you find a workaround (like the sear-skipping hammer scenario above), or the rifle stops in such a manner that it’s capable of firing without the trigger being pressed (broken trigger mech, for example), applying the safety catch definitely won’t help. Or, as hotshot says, your firer automatically operates the weapon after clearing the stoppage, without thinking, hence the safety catch becomes redundant anyway.
News to me. The L81 safety catch isn’t dangerous to use at all, but it can be broken by the ignorant. From memory (been 5 years since I was hands-on with any cadet weapons) it locks the bolt like the No.8 safety catch does, but unlike the super-robust Lee Enfield locking bolt/safety catch arrangement, the L81 safety can be snapped by someone trying (very!) hard to open the bolt with it applied. This results in a small piece of broken metal bouncing around the trigger mech, causing the obvious problem of it jamming in a hard-to-fix position.
Ultimately, does applying the safety catch during an IA drill reduce the likelihood of the weapon being fired while the stoppage is cleared? No. It’s just one more thing for the firer to worry about while trying to unbugger his weapon in double-quick time. You can safely shoot any weapon without ever using the safety - it’s just there as a “last resort” backup for your correctly carried-out drills. I really don’t buy into the “it teaches cadets to think safe” mindset. IMHO, for rangework it does nothing of the sort; it teaches people that if you press the magic button everything will be OK. And that’s a dangerous over-reliance on design features, rather than promoting safe operation. I’d far rather be on a range where people understood the importance of safe direction and carried out their NSPs religiously, than constantly fretted over applying safeties on the firing point - where if a round is fired downrange it’s not going to do much other than drill a hole in the range furniture.
Alternative view: it’s one more thing for them to remember and thus one more thing to get panicky about. KISS. If you genuinely need the “reassurance” of the safety catch, you probably don’t understand how/why the rifle works and shouldn’t be on the firing point without 1:1 supervision.
