Was a long shot. Thanks anyway
eBay. Custom engraved laminated plastic name badeges
Negative. These white-on-blue name-badges are no longer worn in the parent regular service, or active reserves. Obsolete for wear in both Review Order (ie No.1s/no medals or gloves/command insignia) and in all versions of No.2 dress.
The current official RAF pattern name-badges example designs are copied below. I would be very surprised if there wasnāt a direct RAF Air Cadets version: and, if there isnāt already, that could be generated without much difficulty
IYI was pointing out the eBay ones were cheaper and quicker. If you want the above, speak to http://www.namebadgesinternational.co.uk. No affiliation to them. They used to provide the white ones that were the prior iteration to the above. About £6 each. Like a soft silicone cover to the face. Good quality
Namesbadgesinternational⦠I have obscured the nameā¦
Those are the ones.
any chance of a direct link to the item?
No, it was a custom order reference.
this will give you exactly the same:
1 x Prestige Badge
74mm x 20mm, white border, pin fitting.
Style number: PR0402965P
Hope that helps
