MOD90 pic rejection - lack of uniform
Howdy
I have been informed that my photo for my MOD90 (Pers 1-02) was rejected as I wasnt in uniform
So, …what uniform do I wear? Light blue shirt and tie? I dont really have anything else (only been 6 months!)
Would be helpful to have this written somewhere, but I cant see it?
Dress: Applicants are to be in uniform. This is defined as Wedgwood blue shirt and black tie without hat. Jackets or pullovers should not be worn.
This isn’t from a policy per se, it’s just from my Rngl admin hub - I imagine the underlying policy would be in ACP20
MOD 90 photos for RAF personnel are always in No.2A (shirt and tie).
Photog sections usually have a stash of them on a rail near the backdrop, often with Velcro collars at the back or various bits of the shirt missing so that size doesn’t matter so much.
I love this policy.
Must wear shirt and tie
New MoD90 collected. Photo cropped above the collar and tie.
Yeh it’s a bit daft. It really doesn’t matter.
Personally, I like it.
In the Army they didn’t care what you were wearing for your MOD 90 photos and didn’t use proper backdrops.
One of mine was taken in the bar at the TA Centre when I was half cut in a green t-shirt with an obvious bar behind me, another was taken in the changing rooms after using the RCF and so I was bright red, etc.
I need to renew mine and getting a new photo taken is the blocker, because in mine currently I’m clean shaven and not part of the beard brigade
Use the photo machine in you local supermarket or wherever. Wear Wedgewood shirt under a hoody for example, remove that and slip your tie on in the booth, then reverse after photos done. This worked for my last couple, but the guidance is Wedgewood shirt and tie.
I did OC Home’s MoD90 picture at home against a dulex cornflour painted wall in the kitchen…
Pro tip: all smartphones have a timer function, some Bluetooth devices even work as a remote trigger.
If you don’t have a tripod a large paper cup (Starbucks, McDonald’s etc) works as a stand, cut a slit in the bottom to hold the phone, and put it on a shelf, table, whatever. Don’t worry that the phone is ‘landscape’, they are such hi res now you can crop to the right shape.
Choose a plain background and leave plenty of space, then crop to the desired headshot in the photo tool.
@AlexCorbin then ask Claude to add or remove the beard as required and job done.
Or use “portrait” and you’ll easily be able to remove the subject.
My MOD90 is my passport photo so its me in a scruffy old t-shirt.
Weird how some get rejected.
Just checked it.. it’s cropped but you can clearly see it’s a t-shirt and not a Wedgewood and tie haha.
My CI pic for my card was taken in 2017 for my passport; I was also clean shaven.
I know look like I could be in a ZZ Top video and no one would bat an eyelid :man_beard:
A fellow CFAV took mine against a plain background.
Mine has a photo of me visibly tired and hungover on medical day, good to see the army is consistent at least
Finally got mine done tonight, Sainsbury’s in the roughest part of Southampton and I didn’t look the weirdest in shirt, tie, black jeans, old school vans
