I'm bored with whinging - so, a gear thread
Reckon they want a stinky inner?
Sounds like something with an urban dictionary entry
Rogers Profanasaurous…
It’s a bit late now. Tent inner went in the bin and the work has begun on turning the fly sheet into a canoe sail for big raft rigs.
Found this thread by chance!
My single best gear discovery…. Replacing the original insoles that are supplied with all issue boots, with heat moulded ones from a company called Sole.
If you’ve never looked before… the insoles that come with issue boots are a load of pants! They’re thin and utterly pointless. Plus, they become compressed very quickly and offer virtually know support or cushioning.
You should be able to pull them out quite easily to inspect them for yourself.
Don’t be embarrassed if when you pull them out you notice a dark footprint (formed by stale sweat and dirt - unless you bought your boots second hand!)
Been doing this for years, third party insoles make a huge difference.
Sorbothane Insoles - used them for years.
I got a pair of heat moulded insoles many years ago for my shin splints, and still have them [edit: the insoles: not the shin splints!], but I also found that Pro II Wellbeing ones from Amazon are just as good.
Got a couple of tents for camping with the kids - or without the kids.
Both tunnel tents, both with huge vestibules.
Nordisk Oppland SI 2 person. More winter tent, flysheet touches the ground, higher HH. Great in winter, a bit stuffy in summer, and it got quite hot in direct, strong sunlight.
Naturehike Oppalus 3 person - so a bit bigger, materials aren’t quite as tiptop but half the price. more ventilation, and doors on both sides of the vestibule. So far it’s been fine in summer/autumn rubbish weather, but I haven’t taken it out in the conditions that I have the Nordisk. Lighter, cooler, airier in summer
Both just short of 3kg. Naturehike was £200 from a UK supplier, Nordisk was £350 or so from Uttings.
They are very similar designs, and both are outer first construction, and you can clip the inner in if you wish.
For cadets, I’d probably go with the naturehike - it won’t last as long, but it was much more pleasant in the summer than the other. And that saving buys a lot of gear…
And for those of us who don’t like getting cold and/or wet… blues gear? My chip bag is lovely for a nice Spring evening
We bought an MSR Elixir last year and it’s been brilliant. A really spacious design and lightweight, so perfect for trekking. The materials are more lightweight rather than robust, so wouldn’t last long with cadets but a great personal tent.
Just ordered myself a new Palm Nevis, a couple of prussik minding pulleys and some talon mitts. Happy Christmas to me.
But, does it have the sides stitched up or on hooks and eyes for cold weather mode? Then you can do both.
My sister bought me an aeropress for Christmas. I have the Jetboil coffee press, but 10 seconds of thought after putting it together made me realise it’s an awful idea. Because it would leave you with a heck of a mess to clean out of your Jetboil.
Whereas I saw someone use an aeropress at Windermere and it’s a far superior system for making coffee in an outdoors environment, because all of the coffee grounds are kept contained between the filter and the press, and cleaning is easy!
I’ve used an Aeropress at work and in the field for years now; a great piece of kit. The only thing to make sure of is that your drinking vessel of choice has a large enough neck - most jack flasks are too small, so you risk not all of your coffee going in. They sound expensive at first sight; however, depending on your coffee habit, they can pay it back very quickly!
It didn’t fill my usual.mug this morning. (I made my home coffee with it to get used to it. Which was just as well because I made a few mistakes.)
But, it did make quite concentrated coffee, so I just topped it up with more boiling water and it was lovely.
What’s the benefit of an aeropress over a French press, for example?
Not sure I can even get aeropresses over here, but I’m looking for something stronger than instant coffee and I don’t trust the Moka Pot not to explode.
Aeropress is plastic rather than glass. Much better for throwing around!
I’ve also found them significantly easier to clean. You end up with a proper puck of ground at the end that can just pop out!
FWIW, I just use good instant 99% of the time. I love a good coffee, but I dislike faff.
That makes sense.
I also agree - I’m an absolute coffee snob, but ā€œput granules in cup, put water on granules, drinkā€ usually does the job for me, so long as they’re the right granules.
Bizarrely, the coffee-producing country that I’m in seems to struggle with that last bit.
You’re no coffee snob if you drink instant ā€˜coffee’.
