Field Radio
Afternoon all,
I was on Ex recently, and the FS who was IC of comms and radio had this field deployable radio. It was a tube that could be rolled out and erected to make the antenna for a TAIT-style radio base station. If anyone knows of any sort of field radio antenna or quick deployable antenna for creating a base station, then please lmk :slight_smile:
TIA
If you search for inflatable VHF antenna, there are a few products. How well they work on RAFAC VHF frequencies, I don’t know.
Was it a section of plastic tubing or a telescopic type?
Plenty of field type masts out there in the ham radio world.
Could be a Rolatube mast
Rolatubes are great - but not cheap!
Yeah sounds like you are describing a Rolatube.
You could look at getting a Sleeve Antenna, or for VHF/UHF you could get a Roll up Slim-Jim and a telescopic mast.
Or make your own slim-jim from open feeder cable and tune it to RAFAC frequencies Slim jim. This makes a good STEM project and produces a useful antenna for our activities.
Do you what region of pricing you’d be set back by one of these?
They don’t publish pricing but when I spoke to them I think it was a couple of hundred for the mast, depending on the configuration.
Ah okay, cheers!
Apologies in advance, I’m unfamiliar with RAFAC radio quals. Question: Which radios do cadets use? Do you have access to PRR, PRC710 (715/720) or is it entirely civvy based? Does the syllabus cover BATCO etc?
If you have access to Bader SharePoint the policy documents and training ACTOs are there (under cadet training/radio).
As for equipment it varies as it is mostly private purchase, some CCFs have access to PRR.
Does anyone still use BATCO? I thought everyone spoke in clear now and the encryption was in the tech?
