Enamel Poppy regulations
I’ve received many different interpretations of the rules surrounding the wear of enamel poppies on uniform, some say only on MTP dress and others say allowed on MTP and working blue dress but not on jumpers…
What are the rules surrounding when enamel poppies may be worn (i.e. in which dress)?
Thank you!
Quotes from ACP1358
a. Royal British Legion / Poppy Scotland Poppy. The poppy may be worn from the onset of sales and until the National and local observations have concluded. Only the conventional paper poppy is to be worn on ceremonial dress and on parades (with the exception of personnel on ceremonial duties at The Cenotaph on Remembrance Sunday). The paper poppy may be removed at the discretion of a parade commander where it is possible for it to be inadvertently knocked off by arms drill. On working dress and combat uniform, subject to working environment (such as FOD risks), a plain enamel poppy badge of dimensions not exceeding 2.5cm (1”) may be worn as described in para 0133. The plain enamel badge may be worn with Mess dress at the discretion of the PMC or CMC accordingly. Only one poppy, paper or enamel, is to be worn on the outermost garment. Poppies are not to be affixed to head dress.
0133. Emblems (including the poppy) should be of conventional dimensions and are to be worn immediately above the right breast pocket (or inserted in the button hole) of the No 1 SD jacket and in the corresponding position on warm-weather and maternity dresses, jerseys and combat uniform. When worn with the greatcoat it is to be worn on the left lapel. In order to avoid damaging the waterproof materials, emblems are not to be worn with the Moisture Vapour Permeable (MVP) or Jeltex jacket. Similarly, emblems are not to be worn with the GPJ to avoid damage to the outer material.
