Obviously disregarding the current situ (as long the current restrictions end on 02/12) have MT sections reopened? Looking to get my FMT600 but don’t actually know if MT anywhere/ parent stations had actually reopened before they put the current restrictions in place?
TL;DR- Are MT sections open/ will they be open in December?
Depends how wary they remain about external visitors, if they’re running a course (cross-contamination concern, especially if they do a fam drive), or if they are a bit lax on that stuff with CFAV and hand them out on production of your license (not a common approach these days that I know of).
Do you need an FMT 600 would be my initial question as if it is only Cat B there isn’t a requirement.
If it’s initial issue for a minibus then you would be best to ring your local MT, some are open and happy to help when out of lockdown, others not so much depending on how the station is rating the risk and their op committments.
It is for B/D1, having seen the announcement today that places will be able to reopen again in December will give my parent station MT a call and see what they’re running like
You are bang on correct. You don’t need an FMT 600. However there are still a bunch of steps needed to register with your parent station, so I think most of them have stuck with just giving out a 600 as it’s essentially the same process! You have to sign orders (and first time still has to be done on station afaik) so may as well just get a 600 while you’re there!
