What is the procedure for complaining about cadets of a higher rank
If it’s minor, speak to an SNCO. If it’s serious, speak to your CO.
The complaints process is laid out in ACP 20. Ask a member of staff to down load a copy.
Can you say a little bit more about why you want to complain? In all things ATC, where at all possible, use the chain of command. As a cadet, I understand this might be difficult but try where possible. If you jump to the highest rank available, this could cause others issues. Start with a senior cadet NCO and work up, it really depends on the situation and who you can trust to handle it properly.
