i am having issues with cadet portal where it infinitely loads and never gets to an error page any help?
I’ve experienced this as well, although only on one device. The issue usually goes away if you close Cadet Portal and then open it in a few hours, but if it doesn’t then I’d suggest opening it in an incognito window and seeing if that works.
Cadet Portal has been having issues, however it should have been fixed as of about 1900 last night.
ok thanks ill try it on another device later cheers ![]()
