Cadet portal help
Have you tried from a different browser? Looks like it could be Google being the greedy behemoth it has a habit of being and not letting you use any different credentials to log in.
I think this is actually microsoft trying to use your live (microsoft) account. not sure a way around this.
my live Microsoft account is the one i should be using for cadet portal
i used a different browser . still the same issue.imageim using the same image because its the same message
Clear cache and cookies?
nothing there to delete
No. No it’s not.
You should not be using your personal email address to log in to Cadet Portal.
You should be using your Cadet ID (CIN) number @rafac.mod.uk. your CIN is also the number you use to log in to Ultilearn.
THIS FIXED EVERYTHING. thank you
I couldn’t see the wood for the trees. Figured that Google was overriding.
:man_shrugging:
:laughing:
Go back to your original Cadet Portal Welcome email. . .It told you the username to login with.
I’m an hour late!
If I had a Ā£1 for every cadet/parent who has come to me with the same problem… We’ll, I’d have enough for a pint of ale maybe, but you get the idea…
