Brassard
Where does my blue cyber badge go on my brassard, I’m new and I need a bit of help
On Cadet Portal you should be able to find a document called ACP1358, and if you scroll through there’s a diagram. Also, on your achievements page there’s a rough diagram of your brassard, but best to check ACP1358 :grin:
Should also warn you that the badges diagram on the ‘My brassard’ page is out of date - don’t use that one. If you go to the ‘uniform’ page and scroll to the bottom, you’ll find ACP1358, which tells you where to put your badges, and has all the uniform rules if you’re ever unsure of anything else.
Do you mean blue radio?
Blue Cyber, Blue Radio, it’s the same thing (at the moment)
