Where do my blue aviation wings go on my jumper?? This is the only badge i have on my whole jumper if that helps, right now I sewed it on the left patch at the bottom, but fear that I am wrong. Help pleaseee.
Taken from the dress regs:
“Single Badge. When a single badge is worn it is to be positioned centrally 1cm above the bottom edge of the patch of the left shoulder of the jersey BG. When worn with No 1 HD, it is to be positioned centrally 1cm above the top seam of the left hand pocket.”
Hope that helps!
Thank youuu!! That definitely helps, turns out it was in the right place!
