Badges on No1 jacket
So i am a cadet and i have just got a No.1 jacket that i have been authorized to wear for a dining in night, how ever i dont know the positioning for the ranks badges, my gliding wings, or my DofE badge, any help on this will be much appreciated.
Thanks
Tricky
  1. WEARING OF AIRMAN’S NO 1 SD UNIFORM BY CWOs AND SNCO CADETS APPOINTED AS LORD LIEUTENTANTS CADETS
    Although not scaled for, the wearing of No 1 SD uniform, where authorised, cadets are subject to the following regulations.
    a. Authority to wear by ACO - is required in accordance with sub-para 0202e.
    b. Distinguishing Badges - are to be worn on both sleeves with the centre point of the top edge of the badge located 6 mm below the centre of the
    shoulder seam. RAF Eagle Flashes on sleeves are to be removed and ATC / CCF insignia patches are to be attached in their place.
    c. Unit Identification Badges - are to be worn on both sleeves with the top of the squadron number located centrally 5 cm below the shoulder seam.
    d. Rank Badges – CWO Rank Badges are to be positioned on the front centre of both sleeves with the middle of the badge located 16 cm above the cuff.
    NCO Rank Badges are to be worn centrally on the outer face of both uniform sleeves, with the lowest point of the chevrons located 24cm from the shoulder
    seam. The FS metal crown is to be positioned with the base of the crown 3mm above a horizontal line joining upper tips of the chevrons (Preferably to be
    sewn onto avoid making holes in the jacket sleeves).
    e. Flying and gliding Badges - are to be worn in accordance with guidance provided at Para 0418 – 0421, except that a single badge, or lower of 2
    badges, is to be positioned 1 cm above the breast pocket.
    f. Marksman Badges - Only the highest ranking Marksman Badge is to be worn (see Para 0410) and positioned on the right sleeve, 1.2cm above the
    CWO Badge. For NCOs the highest ranking is to be positioned centrally on the right sleeve and with the middle of the badge located 16cm from the cuff.
    g. Classification/Proficiency Badges – CWO are to be worn centrally on the left sleeve with the top of the badge 15cm below the shoulder seam and
    located with a propeller badge vertical. For NCOs are to be worn centrally on the left sleeve and with the middle of the badge located 16cm from the cuff.
    h. DofE Award Badges - are to be worn on the left sleeve, 1.2 cm above the Classification/Proficiency Badge or CWO Rank Badge.
    i. Lord Lieutenant’s Badge – When required to be worn, is to be positioned centrally on the left sleeve 1.2 cm above the Duke of Edinburgh (DofE)
    Award Badge. If the DofE Award Badge is not worn, however, the Lord Lieutenant’s Cadet Badge is to be positioned in its place – i.e. centrally on the left
    sleeve and with the bottom edge of the badge 1.2cm above the CWO rank badge or the Classification /Proficiency badge.
    j. Order of Badges – CWOs. The CWO badges are to be worn as described in papa d. The DofE badge is to be worn as described in Para h and the
    Lord Lieutenant’s badge is to be worn 1.2 cms above the DofE badge on the left sleeve.
    k. Band Badges – are not to be worn so as not to damage the sleeves of the jacket.
  2. WEARING OF AIRMAN’S NO 1 SD UNIFORM BY LORD LIEUTENANT SNCO CADETS
    Lord Lieutenant’s Cadets who are of SNCO rank and are authorised to wear No 1 SD uniform are subject to the regulations for CWOs
    except that:-
    a. Badges of rank are to be worn centrally on the outer face of both uniform sleeves, with the lowest point of the chevrons located 24cm from the shoulder
    seam.
    b. The Lord Lieutenant’s Badge is to be positioned centrally on the left sleeve 1.2 cms above the Duke of Edinburgh (DofE) Award badge. If the DofE
    Award badge is not worn, however, the Lord Lieutenant’s Cadet badge is to be positioned in its place - i.e., centrally on the left sleeve and with the middle
    of the Badge 16 cm above the cuff.
    c. The highest ranking Marksman Badge is to be positioned centrally on the right sleeve and with the middle of the Badge located 16cm from the cuff. The
    Marksman badge is to take precedence over the wearing of a Band Badge in the same location.
AP1358c is your friend go look at it!
As an aside are you a Lord Lieutenants cadet or CWO? Because if you are not your OC has no authority to allow you to wear it - your Regional Commandant does. PARA 202 AP1358c
Thank you very much, i have ap1358c on my phone but i must have been looking in the wrong section.
As for why i’m wearing it, i am a FSC on a VGS and we have our annual dining in night, all the FSC have been given permission to wear a N0.1 jacket with blues trousers white shirt and a black bow tie.
Try to get pair of No1 trousers if you can (as a close a colour match as possible).
Nothing in the world looks worse than wearing a No1 jacket with No2 trousers.
[quote=“wdimagineer2b” post=12832]Try to get pair of No1 trousers if you can (as a close a colour match as possible).
Nothing in the world looks worse than wearing a No1 jacket with No2 trousers.[/quote]
except a Cdt in an ill fitting n01 jacket
[quote=“mabbz” post=12843][quote=“wdimagineer2b” post=12832]Try to get pair of No1 trousers if you can (as a close a colour match as possible).
except a Cdt in an ill fitting n01 jacket[/quote]
True.
Or…
A cadet in an ill-fitting No 1 jacket with No 2 trousers, and a hat 2 sizes too big for them, which has been sat under a pile of junk in the corner of an army surplus store for the last 10 years.
[quote=“Tricky” post=12830]Thank you very much, i have ap1358c on my phone but i must have been looking in the wrong section.
As for why i’m wearing it, i am a FSC on a VGS and we have our annual dining in night, all the FSC have been given permission to wear a N0.1 jacket with blues trousers white shirt and a black bow tie.[/quote]
Well that’s fair enough then if its all official!
