They’re only £30 and they seem quite decent for their price but I am not sure
I’m getting them because I stupidly brought the wrong boots (that weren’t either combat boots or high boots) and so I don’t really have that much money laying around to buy with.
I was considering Altbergs because they were around the same price but they’re all decently used and they look quite manky too from the use
I also generally prefer black over brown which most Altbergs i’ve seen aren’t.
I hate to say it, but cheap, poor quality boots, often ‘Kombat’ probably cause 90% of foot problems I see in the field and road marching. If you can manage it, a pair of good part worn issue boots with a replacement insole are the best option if you cannot afford new, good quality boot.
As a cadet I had a pair of part-worn, and re-soled German para-boots. Good brands to look out for now are Lowa and Meindel (just suggesting what I know from personal use). Also out there which seem to do well are Altberg and Haix issued boots; I’m sure that the denizens of this forum will have their own favourites.
To dial things back a bit, @8ajy62rinjf you can also use the search function to find quite a lot of prior discussions about different boots, but also consider what you actually plan to use them for.
My general advice is that for cutting about the unit and a bit of shooting, then whatever looks the part will do for now, even if they wouldn’t take a beating. BUT if you are looking at getting into fieldcraft, road marching, and more intensive activities then you will be wanting an upgrade later.
It’s then a balance between investing early or buying cheap to save up before buying twice.
If buying second hand, then either go with photos of the actual item or from a dealer that knows how to grade things - Supergrade or Grade 1 is usually decent enough. A couple of scuffs aren’t much of a problem, especially if on the rubberised strips that many modern boots have around the edge.
I got it from a market for 15
But apparently they cost 90 online so god knows how i managed to get that bargain
If i sell it for 60 or 70 then i might have a bigger budget
