I found these really cool boots online: https://www.shoeline.com/product.aspx?style=B350-1500 They do have very few holes in the lining between the tow cap and the main part, for decorative purposes.
I like them because they resemble a narrow width compared to our bulky assault boots from CadetDirect.com.
Let me know if they pass as being accepted, or a boot with that type of level of detail of decorations are not allowed
Mmmmmm
10" is tall. Most military boots are 8"
Not convinced that they are any good, sole looks thin but leather looks supple.
Depends what you want to use them for.
If less than ÂŁ40 then probably ok.
The above is not a recommendation just my opinion.
My recommendation would be go for a pair of Magnums for general cadet activities, Ă s with all foot wear try before you buy.
These seem to be a fashion boot rather than a working boot. As mentioned above the sole looks thin which also then casts doubt on the durability of the leather. Personally I wouldnât bother, certainly not at $180. Plus those decorative dots will make you look like a
Theyâre $200!
They are a poor reproduction of a Jumpboot in the style of equestrian boots.
Paras wear normal boots for Tabbing in. Jumpboots are pointless or obsolete now. The soles are too rigid and the stuff toecaps are a pain, not to mention they are far too high and the Brogue stitching across the toecap looks naff. You want boots that are for getting dirty not for black tie events.
And itâs the cadets, not the Paras you donât need ÂŁ200 boots.
You can pick up some Magnum classics for mega cheap. 10/10 for enthusiasm and thinking outside the box though.
If you are going to spend that sort of money then the world is a shellfish of your choice.
Altberg
Lowa
Hanwag
Matahorn
Adidas GSG9
Top end Magnums
5.11
If you really want to look like an operator, Oakley dessertđ boots.
If you are a 14 year old cadet then donât spend silly money until your feet have stopped growing.
not knowing what a âjumpbootâ is i turned to Google
note the line mainly worn as dress and parade boots - note suitable for Cadet wear.
As indicated the price is foolishly high.
A budget of ÂŁ40-50 will see you with a good boot which is very acceptable.
head down an Armynavy Store and youâll get change from ÂŁ20 with a part worn pair
Have your feet stopped growing?
If they have maybe spend a bit more, if not buy cheaper as you wonât get the use.
Why on earth would you even want those boots? They look ridiculous and are expensive.
100%.
If youâre still growing, get second-hand issue boots, you can pick up decent ones for ÂŁ50 and then sell them when they no longer fit for about ÂŁ40.
hello, thanks for the suport. I am planning to buy them for 50-90 pounds second hand
They look a little⌠âdungeonâ to meâŚ
Much better boots out there for less.
My best advice would be âdonât buy themâ!
They are a little ostentatious and they do not look to me to be at all suitable for our purposes. A quick google has provided a photo of the soles:
No grip. These boots are not going to suit you well on wet, muddy, icy ground.
I think youâll find the calf-height shaft to be a bit restrictive too.
There are reasons why the military really donât wear this style of jump boots any more.
There are plenty of better options out there for the money.
To put it into context, I was able to pick up a brand new pair of Lowa boots for ÂŁ70 on ebay. Theyâve thus far lasted me 5 years and will continue to last with a simple resole job some time in the future.
