I think the reason for the favourability to RAF applicants could have to do with them learning the RAF’s Top secret numbering system to hide things from the russians
simply hide top secret info as a number thats already been used Genius
TBF it’s the same system used to number squadrons and confuse the enemy…
Too true.
Anyway, regardless of planned career choice, all a cadet will do is state that they have always wanted to join the RAF as a pilot / WSO…
Wouldn’t they join RAFAC rather than RAF to be a Wing Staff Officer?
Apologies, i never clicked the link until today, so it may have changed in the last 24+ hours since posted but…
that link now directs to IBN 031-2024 and within that:
have i missed something?
All the IBN says regarding the RAF is
I read this as the RAFAC is following the RAF’s selection ethos by selecting the “quality candidates” for its most attractive opportunity (for the RAF being a Pilot, for the RAFAC, getting a flying scholarship)
Those candidates who do well will be pointed towards an AFCO with a recommendation to join the RAF as a pilot.
Has this been edited since @JoeBloggs first highlighted these concerns that the RAFAC was almost a recruitment process?
another point i notice:
- there is a need to ensure standardisation of the selection process for the GS and aviation opportunities…
- The selection process will be consistent within each Region
All good so far…
- a more pragmatic and discretionary approach might be required to ensure that training opportunities are not missed
while there are hopes to create a standard and consistent approach nationally to how candidates are selected, this last bullet point does act as a (massive imo) disclaimer that those who conduct the selection process still have the ability to use their own discretion
It’s possibly pointing to the fact that some Astra Ground Schools (AGS - the previously stated option for Bronze & various computer based trg) are not available = there has to be declared methodology for selection in those Regions / Wgs, otherwise it wouldn’t be fair to allocate GS / ACPS to those areas not covered by AGS.
Going back a very long time, the ACPS was only awarded to cadets who had attended OASC to complete the aptitude tests (although I have no idea if the required grading was the same as if applying for pilot). However, ACPS was a huge prize of 30 hrs flying, so perhaps understandable that a more vigorous testing procedure was used.
So are the current proposals suitable for the current style of ACPS / amount of flying? If only 40-50 are going to be allocated / flown at AEFs, then maybe it is necessary to filter - but as stated in the IBN, it will be very important to ensure that is is a standard assessment package RAFAC-wide.
The other point about this - what other options could there be if a cadet isn’t selected for ACPS? How about a bursary for some of them so at least they could get some flying - using an external provider of course! ![]()
no, as indicated, i recognised the FAQs on page three…
I had missed the blue box you quote on page 2 - thanks
clearly i had missed this - odd to put it in the box and not in the body of the notice
With only 40-50 slots per year then there has to be filtering.
In the past cadets who applied for ACPS and didn’t quite make the final cut were offered other opportunities like a nav scholarship.
RAFAC made a decision a few years ago to trade time spent on nav scholarships for more AEF flying reducing the aviation offer to older cadets to some degree. If RAFAC doesn’t find the right balance with this then there’s a risk of losing the interest of our older cadets and failing to inspire younger cadets.
We Definately need a broader spectrum in the aviation offer and a better offer in the middle ground (bronze/silver level) to keep the air in RAFAC……
Clearly it’s me not reading properly as I missed that in your post
Sqns/ wgs / regions need to keep pushing for flights in non-Service aircraft. If it’s good enough for OC2FTS (Gp Capt Baz Dale) to sit on the Hon Guild of Air Pilots & help allocate scholarships / bursaries to civvie youths, then the relevant duty of care / safety standards / MoUs are clearly acceptable to him. Time to put them into place for RAFAC. @Cab.
There are no logical “safety” reasons why RAFAC couldn’t move with this; I’ve got copies of the relevant documents that the Air League use - all very sensible. Air League signed an MoU with RAFAC - let’s put some meat on the bone!!
We can’t inspire by theory alone - more flying is needed!
you are right, and it did happen. a neighbouring Sqn whose OC is a BA pilot flew a PA-28 packed with Cadets on more than one occasion via the ACTO035 route before it was rescinded.
all the wording on the relevant documents signed by Cadet’s parents and those in the CoC to approve the activity made it clear the RAFAC was not liable, but it was still deemed “too risky” to continue (with no known situation that occurred to reinforce the opinion of unacceptable risk, eg a near miss)
No one who is pushing for ACTO035 to be reinstated is asking for a shift change to new ground - we had this before, successfully.
Suddenly, without warning or explanation ACTO035 disappeared and with it the process to use non-service aircraft
And even worse, a procedure was being set up to pre-approve some BGA locations to save a lot of the faff under ACTO35. Same principle - the risk (or lack of) was clearly acceptable at the time.
I can’t comment much on here, but it’s grossly unfair to Comdt 2FTS to blame him for the absence of ACTO 35.
I haven’t linked that aspect (although at the time, 2FTS staff were informing me that they “didn’t like cadets flying in non-Service aircraft”) BUT he clearly accepts the civilian duty of care / safety standards, etc used by the Hon Guild of Air Pilots for youth flying. It’s not a big jump of logic to move forwards to accepting these standards / protocols for RAFAC. Throw in a waiver (as per ACTO35) - there is no over-riding reason why this can’t be moved forward.
It IS however, grossly unfair to deny cadets an opportunity to fly in a perfectly safe civilian environment, when the organization is only providing a 9.13% chance of powered flying!
Ha - RAFAC break has started… ![]()
Two emails this morning, both “good news” so not complaining (too much) - one for notification of AEF (in Jan) & the other relating to a Bronze Wings cse (also in Jan) - nominations for that will be required by 29 Dec!!
I think that the new WAvO is still rather keen and has yet to grasp that some like a break over Christmas. Or that we are all stood down for a couple of weeks.
People need to put out of offices on ![]()
