I’m sure I get a lot more use out of my goretex than I do my smock.
Doesn’t that kind of render UBACS pointless though ![]()
That thought did cross my mind, as I typed it.
So what you’re saying is, the relationship between UBACS and body armour is… flexible?
I think the existence of this jacket emphasises the fact that UBACS is not an outer layer.
Need to adapt clothing to the weather conditions.
I would say that the sweating element only matters when it’s in weather when you sweat. Hence when the new combat softshell is worn, UBACS is not neccesary, and could just wear barracks shirt (or field shirt if you are peculiarly a squaddie and that way inclined)
Or a t-shirt. We used to just wear them under combat jackets / smocks after basic training (during which we had to wear green shirts, with the collars folded over the jacket collar).
Edit to add: In fact, when CS95 first came out, I distinctly remember swapping the L/w jacket (now known as a barrack shirt) for the field jacket, and vice versa (with the other kept in the top of the Bergen / day sack).
UBACS was a UOR for hot & dusty places (link below should work), so alternative to a t shirt to give some protection on the arms.
Then it ended up in core
Something I find with the PCS is though it’s meant to layer it doesn’t layer well, due to the proliferation of pockets, Velcro and patches.
Maybe the soft shell could be a flexible mid / outer layer, and it looks smarter in barracks than the smock.
The smock and the field shirt are easily the 2 worst pieces of current issue PCS
And the trousers aren’t great, either!
They’re not the worst IMO
Is there a new smock for PCS23?
I don’t mind the smock but it feels like it was designed for a different era and different type of warfare. It hasn’t changed much from the late Cold War era DPM. Which in turn is based on the WW2 Dennison smock!
There’s better cold and wet weather kit available and it’s not good in hot weather.
Where’s that Chernobyl meme.
“Not great, but it’s not terrible.”
I hope it’s either the softshell, the softie or goretex now. No place for a smock
The field shirt / lightweight jacket is the work of the devil, and can only have been designed by someone who had a warehouse full of hook and loop to use up
That’s my rig, at least when there are no WOs looking. I went on a course and I don’t think any of the DS, and only half the students, had smocks. Rest were in Keela, Carinthia etc.
We need a more robust Goretex. The older heavyweight one was good as an all round outer.
If you want a hard-wearing waterproof, you go Ventile…
All waterproofs have fundamental flaws - they either breathe like tarmac, or have the structural integrity of cling film. Often, they have both.
My favourite waterproof to work in is paramo, but it wouldn’t last long crawling through an Estonian forest…
Had a search around and this will be deliverable mid 2027 which means no one will see them until 2028 probably ![]()
Just seen this about the MTP thermal smock:
