Sadly, Iâm unable to reply to each and every comment as I am on a daily limit, being a newbie on here, so Iâll try and consolidate todays responses into one postâŚalbeit a long post.
Iâm rather unexpectedly putting some extra hours in!
Iâm probably unlikely to change some negative perceptions on here, but Iâll try and clarify to a couple of you who seem to be my hardest audience.
Likelihood and Severity are taught on all Risk Assessment Courses, and should of course be considered when reviewing a RA. It would be difficult to establish and decide upon the relevance of a hazard without doing so.
The chances of getting struck by Lightning, or of a hand gel bottle exploding in a car when itâs sunny are theoretically possibleâŚ. But would be extra ordinary events.
Moist_Van_Lipwig
I repeatâŚ. You do not have to put your cadets through an ELA course. It is merely the easiest way of achieving that little bit extra to push you from a Silver into a Gold. If you want to arrange monthly litter picks around your Community, that would be a good environmental initiative that would count for the same. I would only ask that you consider how youâd evidence that for an assurance visit. Your safety brief to cadets and staff before a Range Session is Health and Safety.
The Risk Assessment should form the basis of your brief before any activity. You donât need to read it out verbatim, but use it as the framework, so that staff and cadets are in no doubt about what to do (or not to do) in the event ofâŚâŚ
The ELA is available to the Scouts, Youth Clubs, and Schools. We donât have the monopoly on the course, and content is dictated to us by the British Safety Council (BSC).
That said, from the weekly discussion we have between the CESO, Safety Centre Team, TSAs and RSAs, I am aware that more engagement will eventually take place between the BSC and ourselves. I already know some good aspirational ideas that will be aimed at the older cadets, and maybe even staff, but that might not happen this year⌠but it will be closer to what youâre hinting at, access to online higher level qualifications up to level 2, with an exam at the end.
Paracetamol
Thanks for running the courses. Please see the response about future plans regarding online H&S courses, possibly at Level 2.
Wdimagineer2b
Youâve got the joint biggest reply paragraphâŚ. But thatâs only because youâre the one of two giving the most push back.
Thank you for clarifying how RA courses were run around 2010.
I again repeat, that the delivery of Cadet ELA courses is left to the individual ELA Mentor to decide. They are given the freedom to go âoff pisteâ to a certain extent.
If you found it to be too simplistic, then put extra activities in as you desire.
All the Safety centre and the RSAs need is a correctly completed Workbook. Iâve had some Sqns getting cadets to fill out the mandatory Monthly check sheet as an additional task. Others get the cadets to draw Posters or create Leaflets.
Be imaginative Wdimagineer2b, this doesnât have to be boring, but if youâre possibly approaching it with a negative attitude, that will be picked up by the cadets, and Iâm sure youâre better and more experienced than that.
What exactly do you think is inadequate about the RA process?
The only recent major changes were the Activity Commander and OCs declaration, which is absolutely to the benefit and advantage of the Sqn OC, removing a lot of the responsibility of the safety of an activity from him or her and placing the responsibility onto the activity commander⌠right where it should be.
Iâm always astonished when Sqn OCs donât buy into thatâŚespecially since the form is coming up to its 4th Birthday⌠the last major change.
The other section is really only to consider environmental impacts of Sqn activities. Something we should have been doing well before we actually did.
The forms are designed to be easy to understand, and amend. They are approved by the Health and Safety Executive. They like them. It meets their requirements.
I again remind you that the Donald Gordon era is over. Time to move on.
You say that only 10% of staff have read ACP5âŚâŚ So, youâve identified a deficiency in what the Staff do.
It is a reference document. Iâd be amazed if anyone could quote it chapter and verse having read it cover to cover⌠I canât!
The Law sits at the top of the Tree. We cannot break that. Beneath it sits JSP375. That will not break the law. It can be MORE stringent than the law, but never less stringent.
It is written to put the Law into Military understanding.
ACP5 sits below that. It cannot contradict the Law or JSP375.
It can (if it chooses) be MORE stringent than the Law and JSP375.
It is written to put the Law and JSP375 into CFAV understanding and speakâŚ. i.e., it contains only the needs to knows and some should knows. It leaves out the ânice to knowsâ, but they can possibly be incorporated if you wish into a future versionâŚ. The end result will be a bigger document, that maybe only 5% of staff will bother reading
RAs ask binary questions, is it as safe as reasonably practicable? Yes or NoâŚ. not âWell sort of safeâ. It is either safe or it isnât.
It is taught that if youâre going around in circles âtryingâ to get to a Yes, and you canât get it to a point whereby you judge it to be safeâŚ. then stop, because the activity is in all likelihood unsafe.
There is always going to be Risk, the question is; Is it acceptable? We only have to manage it sensibly.
On a typical Wing Rugby or Football event, I anticipate at least 10 injuries to be reported onto 492s in the week following the event. The fact that I donât, but know that some were injured is another topic for another day!
There were discussions about using the MOD 5010 in future. It might happen, it might not. Like any amendment, it wonât be changed just for the sake of changing it.
I agree with you about our RA form. Put all the control Measures in Place in the first instance. You are correct, but itâs no use complaining about it. Youâre in a tiny minority.
daws1159
Youâve got the other biggest reply paragraphâŚ. But thatâs only because youâre the one of two giving the most push back.
The RAFAC RA system really winds you up?
You claim that there are impulsive bans. Please (and bearing in mind that I have a reply limit being a newbie) can you cite some examples of this?
What is taught on RA courses is standard Risk Assessment practice, and has been for at least 8 years:
Describe the task
Identify the Hazards involved in all aspects of the activity
identify the Control Measures in Place already to lower the effect of the hazard
Establish if there is anything else can be incorporated to lessen the hazard.
Is the activity Commander happy with those control measures?
Communicate the hazards to everyone involved
Enjoy the activity
Review the RA
For Batfink In respect of identification of Hazards, Likelihood x Severity has always been taught to establish the level of Risk.
You have a duty under the Safe System of Training to get your Risks reduced to As Low As Reasonably Practical (ALARP)âŚ. and if you donât, youâre in breach of the Safe System of TrainingâŚ.
In regards to the Safe System of Training, Staff can whine and moan about it all they like⌠it isnât going away and (thankfully) it isnât going to change anytime soon, because it works, and it applies to everyone. Regulars, Reservists, MOD Civil Servants, Cadets and Staff.
We use the hierarchy of Control Measures at all times.
From best to worst:
Eliminate the hazard (The most effective)
Substitute the hazard for something safer
Engineer Controls
Use Administration to advise of Hazards
Use Personal Protective Equipment (The least Effective)
If youâre NOT doing this already, then you need to start immediately and record that you are doing so.
When you take a generic Risk Assessment Form and add your own hazards and Control Measures⌠Congratulations. Youâve created your own âSpecificâ Risk Assessment. You have utilised a generic RA to your advantage. Youâve done exactly what RSAs encourage you to do.
A Trekking RAâŚ. In my opinion⌠Why not include NFCIs and Hypothermia Risks, AND Heat exhaustion Risks in to one RA regardless of the time of year?
Itâs still a potential hazard and will save you paperwork. You then only need one RA.
Thanks again for allowing me to clarify some aspects of H&S.
I feel a bit like a punchbag, but I sort of anticipated that.
