Cadet Portal Mandatory Training
Good evening everyone. Please may someone guide me on how to access the Cadet Mandatory Training as described on Dashy. We’ve had cadets sign into My RAFAC, and Cadet Portal, yet not be able to find anything that says Mandatory Training.
The likelihood of me being daft and blind is very high, but I would be grateful for any guidance please.
Many thanks
Cadet portal > RAFAC Learn > Course explorer (NOT mandatory trg, it’s not in there for some reason) > either scroll or search for it.
It’s self-enrollment by each cadet, so AFAIK no way for you to do it your end.
It’s a training course on Learn.
I’ve had a flick through it and it seems dated and gives move information than a cadet needs.
just remember even if you have them do it on learn you will still have to then manually add it to their qualifications list.
99% sure this is not the case
@Beans can you confirm?
Thats what I have been told by wing commander as there is no way to view if a cadet has their cold and heat as an activity IC when they do it on learn.
Ah right, that’s correct for Heat & Cold - it’s training to be delivered not just viewed by cadets.
For the Cdt Mand Training:
First Aid - added as a Qual for the various levels, they should have within 6 months of joining. As I understand there is no where documented that they must keep current for their as a cadet but it makes sense to have them renews and stay current (hopefully progress though the PTS) We pull this from the quals.
Climatic Injury - this is also pulled from Quals “Heat Injury - Cadet Presentation” and “Cold Injury - Cadet Presentation” The CFAV delivers this training to the cadets in person and then adds the quals to their record. (we normally each year do an SMS event and add the cadets, deliver the training and bulk add the qual. SMS event helps with the audit)
Heat: In the Bader Learn you can see the course “Cadet Heat illness Training”
Log in to the site | RAFAC Learn You can download the presentation to deliver from here.
Cold: In the Bader Learn you can see the course “Cadet Cold Injury Presentation File” Log in to the site | RAFAC Learn
Bader Training - this is not so much mand training but it is training they should be doing.
Cadet Portal Training: Once off training, this is only available on Bader learn and should be covered in Junior cadet training. There is no Qual it is all bader learn so the cadet just needs to go through it on Bader learn.
Junior Cadet Security: Once off training, this is only available on Bader learn and should be covered in Junior cadet training. There is no Qual it is all bader learn so the cadet just needs to go through it on Bader learn.
Cadet code of conduct: Once off agreement, this is only available on the cadet portal and should be covered in Junior cadet training. Have them log into CP, read the agreement and digitally tick the box to sign it.
Well….. so the Junior cadet Security apparently when the cadet completes the course on learn we were asked to also add the Qual “Security Advice/Assurance Brief (First Class)“ to their record.
The reason was “Unfortunately, it seems it is the SMS elements that is required to be completed, the data is not combined when they carry out a trawl for stats“
So essentially because the bader learn and quals cannot be combined in what ever report is used the ask is for us to all manually add this. My take, no one does this extra manual admin so the report is not accurate.
I just have them do the bader learn course and it marks it as completed. There is no material to deliver instructor lead training so no option but to have the cadets complete on the computer.
think for some of the online courses in bader learn it is ok, but for things like heat/cold/security you really want them instructor lead to make more interactive and they learn more. I do not know why we store the Heat/Cold presentations on bader learn. They should really be on SP or in learn not as a “course” or it get confusing as cadets can look at the heat/cold preso in learn and click "done” but no one looks at heat/cold in learn, we all use the Qual. It is just a bit confusing as you go to the learn course to get the content to deliver and add to quals.
yes its the same issue with the heat and cold from learn doesn’t transfer over to the sms yet.
Hot / Cold injury prevention is not a course that cadets should be self teaching and accessing via Learn. This is training that should be delivered to cadets and the recorded as such on SMS.
SMS is unreliable for checking any qualifications. SMS is on a managed decline as it is being replaced with Volunteer Portal (VP), Cadet Portal (CP) and a new way of authorising events. The most reliable way of checking staff qualifications is through VP. SMEs, OC, other authorised staff and event organisers should be able to do this.
